Hand grips Options
Cassiar1
#1 Posted : 10 February 2016 10:13:28
Rank: Newbie
Hi
I've just started my Fat Boy build & am having issues clicking the handle grips to the handlebar. They just won't click into place & then, because I applied to much pressure, I broke them both.
I have watched the YouTube videos & it should be easy but - No!!
Model-Space are sending me replacements but I'd like some advide before I try again. I don't believe that there is a fault with the handlebar.
Does any one have any thoughts?
Cassiar1
#2 Posted : 11 April 2016 16:25:22
BigGrin Hi Cassiar
Sorry for the late reply sometimes posts can slip through the net but hopefully this will answer your question. The grips inside part the part that fits onto the handle bar] have a button/bubble of plastic inside that is there to hold them both in place when fitted. The problem is that if the handles are removed this button is sliced away and after that they wont stay on.
The other thing to note also the grips are not a tight fit on the handlebars which can give a good deal of movement, the cure I found for both of these problems is to put a spot of superglue on the handle bar and then gently push the grip onto the handle bar until it is fully seated hold for a few seconds till the glue goes off and that should stop any movement and hold them in place.
Best regards
This page was generated in 0.165 seconds.
