Forcastle fit problem Options
Craigo
#1 Posted : 11 February 2016 07:09:46
Rank: Beginner Level 1
Photo of my problem.
#2 Posted : 11 February 2016 08:11:03
BigGrin Hi Craigo I had the same problem but an easy fix. I cut out a peace of ply from the scrap that the parts was fitted to and glued it to the sides of the deck . Once dry , fit and trim . Hope this helps rgd Martyn
Ps if you resize your pictures to 600-400 they will come out as pictures on your posts
Craigo
#3 Posted : 11 February 2016 08:23:57
Confused Thanks Martyn but my problem is at the stern end it does not overhang at all it actually sits inside the hull sides at the stern end. At the bow end it's perfect.
#4 Posted : 11 February 2016 08:29:36
BigGrin just sent you a pmCool
#5 Posted : 11 February 2016 08:47:20
Hi Craigo, this is a problem many of us found and is easily fixed. If you take a look here you will see I had an identical problem..... Hope this helps.
http://forum.model-space...sts&t=5013&p=88
Craigo
#6 Posted : 11 February 2016 09:42:32
BigGrin Thanks Alan. Seeing that reinforcing and the added material to fix the problem is great. I didn't want to just burge on as I wasn't shore how it would effect the build further down the line.
Regards Craig
This page was generated in 0.278 seconds.
