4 Pages «<234
DaDokta´s U-96 Options
#61 Posted : 14 February 2016 12:46:04
Hi Walter, courageous or what!!!! Your heart must have been in your mouth for quite some time whilst carrying out the actions you did.... Hats off to you for doing this and the fab results you achieved.... Very well done indeed.....Cool Cool
alantait
#62 Posted : 14 February 2016 12:56:49
i have the same problem with the warping but never thought of that, a bit scared to try cutting her up. will read and re-read your process ... but might put up with warp. well done and an inspiration with your bravery on this, she looks great now
current builds
DaDokta
#63 Posted : 15 February 2016 08:07:28
Thanks guys for your nice comments!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#64 Posted : 15 February 2016 11:43:33
That was a bold move to make to straighten her up but it's paid off massively, I can see why you're so happy with it ThumpUp
greyhawk
#65 Posted : 15 February 2016 13:21:47
Blink
If there's a Medal of Valor for modelers, you should receive it.
If there isn't, there should be one, so you can receive it.
#66 Posted : 15 February 2016 18:31:21
greyhawk wrote:
Blink
100% agree with greyhawk, bold move and excellent result!!BigGrin ThumpUp
DaDokta
#67 Posted : 25 February 2016 10:43:44
Thanks again, guys!
I spent some hours opening all the vents of the deck-side parts, which was especially hard at the small vents with all the plastic to be removed on the inside!
I then attached the parts to the deck-Frames.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#68 Posted : 25 February 2016 14:15:40
Nice work on those vents Walter Cool Regards PhilThumpUp
daffy09
#69 Posted : 25 February 2016 14:59:09
Lovely work Walter, those vents look so much better when they have been opened up. It's a time consuming job but the results speak for themselves, good work.
Happy building
David
#70 Posted : 25 February 2016 15:52:10
Looking good Walter, the vents definitely look much better after having been opened Cool
#71 Posted : 25 February 2016 18:23:43
BigGrin Very nice work WalterCool
#72 Posted : 25 February 2016 19:30:52
Hi Walter from what i can see i don`t think we do open that hole i think it`s for the bow planesCool regards Phil
DaDokta
#73 Posted : 25 February 2016 19:48:29
Thanks Phil - will keep them closed as it will be no problem to open them up later on if necessary.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#74 Posted : 25 February 2016 20:18:08
Your doing a great job with this one. Hope its giving you lots of fun building it.
#75 Posted : 25 February 2016 23:58:59
Certainly coming along Walter, looking great....Cool Cool
DaDokta
#76 Posted : 02 March 2016 11:27:08
Hi guys!
I´d like to show you some pics of this weekend`s work.
First i completed the first planking at the stern and attached the side plates.
Then i test-fitted all the deck frames (removed them again)
Next step i glued the stern parts. I had to cut the metal-tube to about three cm - otherwise it would not hev been possible to attach the Stern to the hull in the right position (the shorter tube is not visible)
I then attached the stern to the hull along with the stern-most deck Frame:
I must say i dont`t look forward to the sanding-job as most of the second planking is more than 1mm higher then the plastic parts - so this will be a pain i guess?
Thanks for looking in!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#77 Posted : 02 March 2016 12:57:59
Nice job Walter she`s starting to come together now Cool you could always purchase a mouse sander to help youCool or you`ll get popeye arms and will after eat spinach BigGrin regards Phil
DaDokta
#78 Posted : 27 October 2020 19:44:43
This build won`t be continued!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
4 Pages «<234
This page was generated in 0.290 seconds.
