4 Pages «<234
Marsot Sky Drone Build Options
Marsot
#61 Posted : 14 February 2016 17:11:02
Stage 38
Installation of the ESC connector cable on the chassis
Marsot attached the following image(s):
______________________________________________________________________________________________
Building: Sky Drone, HMS Victory, Mary Rose
Wishlist: Spitfire
http://www.sotheran.com
Marsot
#62 Posted : 14 February 2016 17:14:32
Thanks Dellboy,
I've starting to enjoy this build again - and I certainly will include a video of first flight!
Wishlist: Spitfire
Marsot
#63 Posted : 14 February 2016 17:20:57
Stages 39 and 41
Fixing the Drone's outer shell with strong double-sided adhesive tape.
The parts seen in the next three photos are:
Body Top - supplied Stage 39
Body Side - supplied Stage 1
Body Front - supplied Stage 41
And I know I am jumping a bit ahead of the plan be I just had to see what it would look like on the chassis!
Wishlist: Spitfire
Marsot
#64 Posted : 14 February 2016 17:27:50
Stage 40
This photo shows the three Electronic Speed Controls (ESC's) in place with double-sided tape.
Wishlist: Spitfire
Marsot
#65 Posted : 14 February 2016 17:31:01
Stage 42
In this stage we build and install the mounting bracket and support for an optional action cam.
Wishlist: Spitfire
Marsot
#66 Posted : 14 February 2016 17:41:35
Stages 43, 44, 45, 47
In these Stages I built the last remaining Rotor arm (rear right), including fixing the red LED lights and covers; the rear rotor guard support; the rear right rotor and connecting it all to the chassis.
Wishlist: Spitfire
Marsot
#67 Posted : 14 February 2016 17:45:11
Stage 46
Fitting the switch and flight circuit board onto the rear of the chassis.
Wishlist: Spitfire
Marsot
#68 Posted : 14 February 2016 17:48:23
Stage 48
Fitting the rear LED board to the chassis and installing the forth rotor arm
Wishlist: Spitfire
Marsot
#69 Posted : 14 February 2016 17:52:52
Stage 49
Fitting the fourth Electronic Speed Control (ESC) in the drone and wire up the components.
Wishlist: Spitfire
Marsot
#70 Posted : 14 February 2016 17:59:34
Stage 50
Completing the chassis
Assembling the remaining components - top of the chassis, front and rear components, and screw them all down.
It looking good now - the instructions say "there's not much further to go before your Sky Rider Drone takes to the skies!"
Wishlist: Spitfire
4 Pages «<234
This page was generated in 0.905 seconds.
