Stynylrez Primers Options
#1 Posted : 27 February 2016 06:51:40
Hi All,BigGrin
Now I don`t know a lot about this primer, (well nothing really), but if it does what it says on the tin, sorry, plastic bottle then it sounds good.Blink
Non Toxic
Non flammable
Self Leveling
and
Sprayable without thinning.
As a bonus, made by Badger.
ScaleModelShop are a UK distributor and do single pots in two sizes and a set of three different colours in two sizes.
Heck here`s a link:
Primer
#2 Posted : 27 February 2016 12:16:24
Hi Derek
Be interested to see how you get on with this one as i saw it being advertised last weekend and for me it ticks all the boxes.
While i have no experience i am going to assume the hardening time might be a little longer in the basis it does not have those quick drying pwerful and stinky solvents in it.
I noticed it comes in A range of colours as well so useful indeed.
I am wondering if badger have struck a deal with someone like valejo to supply a known product under their own label?
michu
#3 Posted : 27 February 2016 12:27:52
From what I heard, people swear by them. Pretty common opinion is they are the best on the market. Spray with .4 or .5 needle at 20-30 psi with light covers until base plastic colour disappears and should be perfect. Ready for painting in 5-8 minutes.
This happened just after UMP released their line of primers that is just repackaged Stynylrez, just less colours to start with and a bit more expensive. I received my batch of UMP two days ago and if all goes well, I'll have a chance to try them this weekend, so I'll share my impressions.
Happy building :-)
#4 Posted : 27 February 2016 12:33:53
Michal
Looking forward to seeing what you make of these.
#5 Posted : 27 February 2016 13:33:42
I used this primer on my T90 build and was very impressed, it gives a beautiful finish.
I found I had to ramp the pressure up to 30-35psi with a 0.5mm needle as it's quite thick. It helps to warm the primer up first in a bowl of hot water.
I was so impressed I now have every colour that they do BigGrin
#6 Posted : 27 February 2016 13:39:20
Hmmm I use the Vallejo range, but going by all your comments, I may have to give these a try!BigGrin
This page was generated in 0.128 seconds.
