help, broblem with the bow Options
pall mall
#1 Posted : 08 October 2010 18:41:46
Rank: Beginner Level 3
hi mates its me again with another problem.
plank 11 at the bow is low on the port and high on the starboard but both sides meet in the middle,i have thaught about putting a contiuas plank around the bow from port to starboard on row 12,what do you lads think, ( and hopefully you wont tell me to strip the planks again)any advice is gladley excepted.Blink Blink Blink
#2 Posted : 08 October 2010 18:48:19
you will get variance with the planking,don't worry too much,check tomicks build carefully
to see if you can see where you went wrong,and don't dispare we all get these problems.it looks like you need to solve this yourself,and some pics would help us to give you the right answer.
willie
#3 Posted : 08 October 2010 19:52:30
follow the tip 7b in the mag triming no11 and no 12 planks if you have glued no 11 tapper it with a rasor raw adjust no 12 to suit or may be try no12 with out tapper run over top of n011 trim no11 to suit un tapperd no12
pall mall
#4 Posted : 09 October 2010 09:30:19
thanks lads
This page was generated in 0.282 seconds.
