32 Pages «<2324252627>»
tf64 Spitfire Build Options
#481 Posted : 02 February 2016 01:32:19
Hi Trev BigGrin
Can only agree with Kev's words. A cracking build.
Cool Cool Cool Cool Cool
#482 Posted : 02 February 2016 11:13:24
tf64 wrote:
Hi Kev.
How pleased I am to read that you are following my Spit build with interest, I have a great enthusiasm for plane builds as with the interest I have for your builds, in particular with your foil project that's takes great skills and worth every comment you receive, and that's how I feel when I received your last post to me.
Thank you Kev
Trev.
Hello Trev,
Thanks for your compliments about my foiling, very much appreciated and I really do enjoy following your Spitfire build mate, I'm always looking forward to every new update from you!! Cool ThumpUp
I am very happy to compliment you on your own work Trev, it is excellent, so credit where it is due my friend? Keep up the good work!! Drool Drool Cool ThumpUp
#483 Posted : 02 February 2016 13:24:01
Been a little while since I dropped in on this, Build is really looking good. It is certainly a proper model builders kit Cool Cool Cool
#484 Posted : 02 February 2016 20:07:00
Looking pretty sweet Trev ThumpUp keep the fantastic updates coming Cool
#485 Posted : 02 February 2016 20:45:40
Brilliant work Trev, she is going to be a stunner when done!BigGrin
#486 Posted : 02 February 2016 21:09:57
Excellent work Trev especially on the landing gear Cool Phil
#487 Posted : 03 February 2016 19:49:07
Hi,
Delboy, Kev, Jase, Dave, Nem, Tigerace.
My thanks go to you all for your grateful comments.
Update on the tailfin so far is that I have built the edges of the stabilizers up with 3x5 mm wood to match the height of the leading edge ( metal parts ).
More soon.
Trev.
#488 Posted : 28 February 2016 13:20:48
UPDATE: SPITFIRE.
280216.
Tailfin.
Fitting Metal Edges.
Fitting Wood Internal Reinforcements to Stabilisers.
This week final fit to all metal edges on the tail fin plus wooden internal reinforcements topside and underside to the stabilisers' have fitted more reinforcements to my build than the official build but that's me, what I did find when fitting it was easier to file down the wood strips to were they meet the metal parts before you cut them.
I found it a lot less difficult to hold the wood strip and sand or file before cutting to length as they are small parts.
Tail Section with Leading Edge, Stabilisers, Wood Reinforcements fitted next to fit metal plates to Tailfin.
Thanks for looking.
Trev.
#489 Posted : 28 February 2016 16:48:48
Trev.
This is looking wonderful.
I think the build would be a bit beyond my capabilities as it does seem to need a steady hand and keen eye to get the best out of the parts supplied.
Hope the rest of the build goes well.
alemo
#490 Posted : 28 February 2016 17:18:09
Hi Trev,
I have spent two very pleasant afternoons reading your build log from start to present day and was inspired to order the spitfire for myself.
My wife asked "where will you put it?" I replied "worry about that in 32 Months time".
My work space is only large enough for one build at a time and as my D51 is completed I felt lost without a model.
Thanks to you, part one has arrived and I'm underway and looking forward to the build.
Very impressed with your work, I hope that I can achieve as good a build as you are.
Thanks for the inspiration.
Regards, Alec
Adapt, improvise, overcome.
#491 Posted : 28 February 2016 18:06:58
BigGrin Looks great Trev and nice workCool
#492 Posted : 28 February 2016 20:12:35
birdaj2 wrote:
Trev.
Hi Tony,
This this is one of the easy builds, most of the parts are already cut to shape and very well done to, so it's just a matter of assemble and taking your time. The only parts on my build that needed attention were some of the metal parts where they would not line up with out adjustment.
Thank you for looking in.
Trev
#493 Posted : 28 February 2016 20:33:00
alemo wrote:
Hi Trev,
Regards, Alec
Hi Alac,
Welcome to the Spitfire builds, first thank you for reading my build diary, as you know the Spit diary runs for 32 months I have received 30 issues but still a lot to do, this has been a great build for me and I am pleased you have received your first part.
You say you have limited work space the only time the spit gets large will be when you join the wings to the fuselage by then you will be used to it and it won't be a problem it will just be a great build.
Looking forward to your pictures.
Trev
#494 Posted : 28 February 2016 20:35:49
Hi Andy,
Thanks for looking and your comments, always welcome.
Trev.
#495 Posted : 29 February 2016 00:38:07
Another great update Trev, thoroughly enjoying following your progress....Cool Cool .. Look forward to your next update.
#496 Posted : 29 February 2016 12:08:40
A cracking build Trev, so very neat and tidy and you've managed to achieve a superb fit to those metal leading/trailing edges, couldn't be better!! Great work on the rivet detail for the fin panels too, it takes some skill to get them straight like that - especially on such an awkwardly shaped panel!! Cool Cool
Very well done my friend, getting nearer to the finish line now and I'm certainly looking forward to seeing the end result!! Drool Cool ThumpUp
#497 Posted : 02 March 2016 19:53:55
Hi Alan,
Thanks for looking in, just need to finish the plating on the tail plane and I can push on with the Fuselage which won't be long now, there will be another update on the tail plane at the weekend.
Trev.
#498 Posted : 02 March 2016 20:05:57
Hi Kev,
Thank you for your nice comments, I did have a bit of a problem as one of the leading edges would not line up, the reason was that I had to chamfer a small angle on the back edge of the stabiliser to let it in a bit which then lined up, plus a small amount of metal filing to finish it off.
All good fun.
Trev.
#499 Posted : 02 March 2016 21:38:25
tf64 wrote:
Hi Kev,
All good fun.
Trev.
Hello again Trev,
Thanks for the insight into your methods for achieving such a great finish my friend, very interesting and yes I agree, "all good fun", but it's the little problems that make modelmaking so interesting inmy opinion and will always give such a great feeling of satisfaction when they have been overcome? I'd be bored if every build went together without fault!! BigGrin
Keep up the great work Trev. Cool ThumpUp
#500 Posted : 05 March 2016 11:02:48
UPDATE:SPITFIRE.
050316.
Assemble Metal Parts To Tail plane.
This is a small update today my main objective will be to rivet and fit the tailfin metal parts and then move on to the stabilisers and Tailfin rudder.
The picture below is about as far as I am at present, should be an interesting day.
Trev.
This page was generated in 0.938 seconds.
