Using Microsol & Microset Options
#1 Posted : 05 March 2016 12:48:31
Novice modellers may find this useful if they haven't used Microsol or Microset decal fluids before.....
http://incunabulum.co.uk...icroset/comment-page-1/
#2 Posted : 05 March 2016 15:09:05
Great article.Dont forget to test the setting solutions on some decals first.Sometimes they will destroy decals,especaily if they are very thin.Secondly (especially microsol) can react with some paints so either do a clear coat if you are nut sure or test the solution on a paint sample first.
Finally do not try to move the decal once you have applied microsol-It will tear if you try to move it.
#3 Posted : 05 March 2016 18:34:52
where in the uk can you get johnsons klear ? everytime i look on various sites comes up with pledge klear is this similarConfused cheer`s Phil
#4 Posted : 05 March 2016 18:46:12
Hi,BigGrin
May be mistaken, but it may now be owned by pledge. Confused
The original link in this thread was dated 2009.
Amazon link
Update: Now known as "Pledge multi-surface wax"
Asda / Sainsbury. NOT Tesco
#5 Posted : 05 March 2016 22:23:16
I was trying for ages to find a bottle of Kleer for my Scramble diorama - can't find it anywhere in the Plymouth area, ended up having to use Humbrol's Clear Gloss Varnish, much the same but a lot more expensive !!Cursing
#6 Posted : 05 March 2016 22:33:23
Klear is no longer available, its now known as pledge. The odd bottle pops up on flea bay but its fetching 50+ pounds a bottle!!!
This page was generated in 0.134 seconds.
