Wow, this is turning out to be something special....  .. Looking fab... Regards Alan
Joined: 19/05/2015 Posts: 1,419 Points: 4,272 Location: Darmstadt, Germany
Let there be light!
Looking great.Its a shame it wont be released in USA.
darbyvet wrote:Looking great.Its a shame it wont be released in USA.
Does Hachette not do partworks in the US?
greyhawk wrote:darbyvet wrote:Looking great.Its a shame it wont be released in USA.
Does Hachette not do partworks in the US? Not as far as I know Carl
Damn, that IS a shame.
Making nice progress GH and beginning to look like an aircraft now with that large metal plate giving a good idea of where things will go and the size of it?
It's rather BIG isn't it!!?
Kev
Yeah, it'll be about 60cm long. Issue 7 - Installing the Radar AN/APG-71  Another air intake, the radar and its holding bracket. Here's where the difference between European and Japanese versions of this kit comes to light. While the Japanese get a nice cardboard box every week, we only get our stuff dumped in a plastic bag. Which leads to situations like this week where one of the 0,5 mm long and 0,less mm thick pins on the holding bracket clean broke at delivery. I cut it off and glued it on again, but this is really avoidable, Hachette, just dump the stuff into a little cardboard thingy, this isn't that hard. Anyways, the radar is installed and the purists are going "what in heavens name is that thing" now.  Yeah, I don't know whats up with that colouring on the radar either. I'm relatively confident that Hachette will provide advice on how to correct this colour scheme in the future (as they did in issues before), so I'm not going to touch it up just now yet.  We also fit the air intakes. They're screwed in and that's that. Next week, the first landing gear door, sweet.
 looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
That is a big model indeed and will look brilliant when finished. Not sure if there are many other aircraft kits of this detail in this scale. Again snother one i would love but would struggle to find thecspace to display it. Hope the build continues to go well. Happy Modelling
Issue 8 - Installing the port side landing gear doors  We receive the elements for the ports side landing gear doors and the frame they are to be attached to as wall as metal rods and screws. Both doors are fastened to the frame with the metal rods. This is a very tight fit and at least for the front door required some tricky maneuvering and accident prone use of needle nose pliers, thin pieces of metal and a hammer. Luckily both me and the parts lived through that uninjured.  Pictured at a moment the front door rod was not yet fully inserted. It is now. Attaching the door frame to the central frame of the kit again was rather tight and again required the use of padded pliers to temporarily slightly bend parts until everything clicks into place and can be screwed together.  Pictured: some very minute misalignment in the angles of the doors. This has been corrected now.
Looking good Greyfox, I'm glad you managed to get away with not injuring yourself
That is looking very smart. I do like the idea of having the strong metal skeleton onto which the parts fit. Happy Modelling
davetwin wrote:Looking good Greyfox, I'm glad you managed to get away with not injuring yourself Do believe me, I tried to stab me with a lot of things today but somehow kept missing.
ooh its going to be a monster.
Indeed. That's a 30cm / 12 inch ruler for scale
Joined: 05/02/2015 Posts: 46 Points: 141 Location: Perth, Australia
hrmmmm.. decisions decisions...
subscribe to Millenium falcon, or wait and see if this is released in Australia...
To me the answer is clearly: both. No, but for reals, the Falcon is coming out in Australia now, the F14 maybe in 2018 (they'll go for the UK first in 2017 i would guess)
you make a good point sir!
Issue 9 - Installing the first "engine"  Fake engine of course. We receive a motor, bracket for the motor and a turbine fan. All parts are simply plugged into each other and then stuck onto the central frame. Looking pretty fly.
Guest (35)
