Joined: 11/03/2010 Posts: 234 Points: 734 Location: Whelpley Hill, Chesham
Nice neat job as always. Like your rivet marking on the metal components, good to know the marking tool is still working well nearing the end of the project. Looking forward to the next update. Regards, Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Adapt, improvise, overcome.
Looking good Trev, very nice work indeed!!
Lovely work as always Trev, I'm really enjoying this build of yours!!
Have a very enjoyable days modelling Trev and I'm really looking forward to seeing all that sheet metal fitted - well done!!
Kev
Very nice job Trev, those rivets look like they would be tedious work but by the looks of it you haven't let that put you off as they look spot on
Trev, Very nice to see it coming along so well. See the offer on the kit today and must admit to being tempted but not sure if i would be very good at adding all that rivit detail as i guess you only get the one try per piece. Hope it continues to go well. Happy Modelling
Hi Alemo, Thanks for looking in, as for the Rivets once you start you realise that a lot of thoughts about riveting are soon lost, when you start and you will find that your confidence will grow, in fact the riveting I now do is all free hand. More soon. Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Nem, Thanks for your comments. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Kev, Had a good day on the Spit will update Sunday. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Dave, I must say that Riveting seem's to me as one of those jobs that one slip and you are found to be speaking Queens English. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Tony, Thanks for your comments, be tempted with your skill level you will love it, a great kit just waiting for you. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE:SPTIFIRE. 060316. TAIL RUDDER SECTION. REAR LIGHTING WIRE. TIP: Metal Plates: Make adjustments to fit before riveting this is very important or you can lose them if you adjust afterwards.  Rudder section after making adjustments to the metal plate to fit, also shows where I have cut out a small section of wood to allow lighting cable to fit.  Metal plate rivet marked and ready to be glued in place, also shows a check fit to cable.  Remove cable and clamp plate to set 24 hours.  Final picture with metal plate and rear lighting in place. Next will be Tailfin and Stabilisers. Thanks for looking. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE:SPITFIRE. 100316. METAL PLATES TO ELEVATORS.  This shows the Rudder and Elevators complete with metal plates, fitted top and bottom with rivet markings.    This shows Tailfin/Elevators/Rudder with metal plates fitted. The next part will be to make slits to fit hinges into the tail rudder and stabilisers. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Fantastic work Trev
Trev That looks brilliant and its certainly a kit for the skilled model maker of which you clearly are. Hope the rest if the build goes well. Happy Modelling
That looks terrific, you must be well pleased with the way that it's shaping up. Regards, Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Simply stunning work Trev, you have to be well chuffed with the way this is turning out......  .. Keep those great pics coming...... Regards Alan
Hi Trev, The tail end looks spot on, as does the rest of your build. A credit to your skill and patience for the time put in. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Trev  . Your spit is looking fantastic and the rivet detail is amazing  . Keep up the awesome work. Best regards. Mark
Joined: 19/05/2015 Posts: 1,419 Points: 4,272 Location: Darmstadt, Germany
Stunning work, Trev. I love how tidy this looks.
As i said multiple times - loving your build and learning a lot! Greetings, Walter
Guest (6)
