29 Pages «<56789>»
karls new victory build Options
#121 Posted : 08 October 2010 17:34:40
#122 Posted : 08 October 2010 17:35:55
budgie
#123 Posted : 08 October 2010 17:45:19
hi Karl nice pics i can see ure build is coming along nicely(would'nt expect any thing else)
LIDL got set of chisels £5.00 odds by POWERFIX
would u reccommend them or best to stick to well known brand????
#124 Posted : 08 October 2010 18:41:34
thanks bodge,but just bought a set of proxxon chisels.
#125 Posted : 08 October 2010 21:54:34
You generally get what you pay for. I would guess that they will not keep a sharp edge for very long, and may be difficult to sharpen. I have a cheap plane which worked brilliantly for a week, but now it needs sharpening frequently. Fine if it's only for occasional use.
#126 Posted : 10 October 2010 13:51:15
thought I'd better put it somewhere safe,or buy a new house..............no money left,leave it where it is.
hudsonrobert49
#127 Posted : 10 October 2010 14:00:09
Class LOL
Rob
Bridlington.
Mac
#128 Posted : 10 October 2010 14:25:17
Like it Karl LOL LOL
Pam's shipyard is closed for now no more room!
bripfc
#129 Posted : 10 October 2010 14:36:39
so what kit does the dry dock come from ??? i want oneLaugh Laugh
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
PLAY UP POMPEY!!!no wise cracks
axle396
#130 Posted : 10 October 2010 14:42:21
Amen to that. You should always buy the best you can afford. Cheap tools are, more often than not, a false economy.
Jimmy L.
Revell USS Kearsarge
Titanic Lifeboat
axle396
#131 Posted : 10 October 2010 14:45:08
Build coming along great Karl. You are fast. I'm only on my second row of planking.
Jimmy L.
Titanic Lifeboat
Son of Bulwark
#132 Posted : 10 October 2010 19:20:20
Looking good Karl! Cool
Like the Dry Dock must have cost a packet to rent that!. You’d better charge the visitors to look around your ship when does the tour start.
ThumpUp Darron
#133 Posted : 14 October 2010 16:04:48
as this is now official,(no veneer)I shall strip my hull down and re-plank in walnut,very very disappointed in art-latina,is now truly a budget kit,every other manufacturer puts out double planking of the victory,I'm only staying with the build,for the cannons and figures,
the victory we are getting bears no resemblance to the one shown on the advertisments.
#134 Posted : 14 October 2010 17:49:06
The build is looking excellent Karl, just want to raise an old question regarding rib 15 mate, I know we are adding and subtracting peices of wood to compensate for any irregularities with the ribs, but how far out were the tops of rib 15 in relation to the planking, or if you got around the problem, what did you do? I'm at present on issue 23 and beginning the gun ports, much obliged...Thanks mate...
Unsure
#135 Posted : 14 October 2010 21:15:00
jonny rib15 doe'snt rear it's ugly head until you get to row 15,had to remove 5 layers of planks and refill ribs16,17,18, 19, on starboard side only,I will put up pics tomorrow showing the problem,but now I'm stripping her,I can re-adjust the ribs then.
#136 Posted : 15 October 2010 11:27:38
Thanks Karl...looking forward to your next pictures and alteration ideas with eagerness mate...Blink
Son of Bulwark
#137 Posted : 15 October 2010 14:07:49
Hi Karl! BigGrin
I hope I got to you before you strip down your hull and re-plank it. If you what to put a veneer on the hull score down the planks with a craft knife at about 1 inch apart only score to about 0.5mm deep then sand with course sand paper. When the score lines have gone, us fine sand paper to finish the hull, before gluing your chosen veneer on top of the lime wood planks. Use 0.5mm veneer planks, if you what to use 1mm planks then repeat the scoring of the planks to reduce the thickness to 1mm.
It would be a shame to remove your all your hard work so use what you have as the first layer of planking.
Tomick wrote in the thread Hull Planking, Posted: 12 August 2010 08:16:32
"Overall single planked, but the bottom half of the hull will also be skinned with dark veneer planking."
ThumpUp Darron
#138 Posted : 15 October 2010 16:39:30
sorry darren,had to strip to get it out of my system,flamin' angry with de-ag,yes I thought the lower half was getting a veneer overcoat,but admin said a few day's ago that it was basswood all over,so supplying my own wood on the exterior.
hudsonrobert49
#139 Posted : 15 October 2010 16:56:46
WOW karl1113 I feel for you, for all that hard work you put in to Her.
Rob
Bridlington.
Son of Bulwark
#140 Posted : 15 October 2010 17:09:56
Yes Karl!
Quote:
Quote:
axle396 wrote:
Hi Admin,
Can you tell me if the ship hull is to be double planked.
Cheers,
Jimmy
Admin wrote in the thread HMS Victory hull,#20 Posted : 12 October 2010 15:01:45
Quote:
Hi All
The hull will be single-planked and can be painted, lightly stained to the colour shown in the finished photos, or coppered, as you prefer. The wood we are supplying is lime (US term 'basswood'). Lime is a hardwood that is also flexible and easily worked, so it's ideal for the purpose. It was used for some of the finest historic carvings in Europe, including those by Grinling Gibbons, whose work included Blenheim Palace and St Paul's Cathedral. Therefore there will be no veneer.
Thanks
Admin
As you can see Tomick says one thing and then Admin say another then lock the Ask Admin section of the forum.Cursing
You just can't get a straight answer can you Karl. I would be more inclined to believe Tomick as he is doing the Official Build and Admin is just answering questions and might not know what the real answer is!.
If Admin was wrong you will be kicking yourself. Still a little cleanup work on the hull and you will be soon be planking the way you want!.
DON'T LET THEM BEAT YOU!ThumpUp Darron
Guest (22)
29 Pages «<56789>»
This page was generated in 0.185 seconds.
