Nose section Options
ALW
#1 Posted : 10 March 2016 21:18:55
Hi all
Is there any reason why the nose section cannot be attached to the fuselage
at stage 14? Sorry pack 14!
Thank you
#2 Posted : 10 March 2016 22:56:52
ALW wrote:
Hi all
Thank you
Hi Alan,BigGrin
I have taken a good look at the instructions and the official build.
There is still a little bit of work to do on the front end of the fuselage, in Pack 17 stage 67(just before the instructions tell you to fit the nose).
My suggestion, would be for you to read the official build and your instructions thoroughly before you make any decision to jump forward in your build.
At the end of the day the decision is yours, but you have to realise you may cause yourself some difficulties further along in your build.
ALW
#3 Posted : 10 March 2016 23:13:39
Thanks Derek
I'm at that stage where it's starting to take shape and eager to
get it finished.
But must be patient!
#4 Posted : 11 March 2016 09:56:43
Hi Alan,
Just read your post regarding nose section and I have to agree with Derek on this one.
There are more parts to be fitted to the nose section i.e. more reinforcements etc.
Also your next stage will be to assemble the engine top cover and fit reinforcements to that, and you may have to make adjustment's to fit it correctly, so if you fit the two parts together now you would have the length of the fuselage to support as well, which would be awkward and get in the way.
Trev.
ALW
#5 Posted : 11 March 2016 11:50:23
Thanks Trev
This page was generated in 0.212 seconds.
