7 Pages <1234>»
Frederick the Victorious and the Battle of Seckenheim 1462 Options
#21 Posted : 03 March 2016 11:46:08
Many thanks for that Kev, that's a great idea! Funnily enough we only threw out one of those tubes of tomato puree just before Christmas - it never occurred to me to salvage that tube (mind you, the use by date was around the year 2000!LOL )
I'm currently working on the armour 'improvements' at the moment and tescos is involved in that as well - I never thought I'd be using tuna in this build!!Blink
Back soon.
Robin.
#22 Posted : 03 March 2016 14:45:37
I got a bit behind with your log but have now caught up and wow, the progress made on this is jaw dropping.
The finish you've achieved with the steel looks so realistic, the effect of the wash certainly did its job Blink
Despite the mishap you had it has come out looking pretty special, I'm now already eagerly awaiting your next update Cool
#23 Posted : 06 March 2016 20:04:59
Thanks so much for those kind words Dave!Blushing I suppose, where the surgery on Frederick's head is concerned, "jaw dropping" is about as apt as you can get!!LOL
OK then, with this instalment, we begin the complicated part of the main torso section of the model. In Photo 1 we have the front torso half as it comes out of the box. Looking at this overall shot, the top neckpiece or neck-guard is called the BEVOR. In later centuries, ie, the time of the Wars of the Roses, the Bevor was a separate collar which came up underneath the sallet helmet to mouth level, but in the case of Frederick’s armour the Bevor is fixed to the Helm itself. Below the Bevor is the BREASTPLATE. The breastplate, unlike classical Greek and Roman examples is composed of two sections not just one. The upper or inner part is actually called the breastplate but the lower or outer part is known as the PLACARD. The Helm is attached to the Placard via the Bevor by a stout leather strap front and back, which, as you can see here is represented by an already moulded on strap and buckle. Below the Placard are a series of overlapping steel hoops running from the upper thighs to the waist, this is the FAULD. In most medieval suits of armour of this time this would be the lowest part of the body armour with the legs protected by their own plates. Some suits however (especially those belonging to the highest nobility) would have extra protection for the upper thighs consisting of two shaped steel plates strapped to the Fauld called TASSETS. In the kit these are also moulded onto the main torso as shown here.
OK, that’s most of the history lesson done (well done those still reading!)BigGrin In Photo 2 we start the surgery! The first task is to remove the Tassets from the bottom of the torso piece. There are no simple straight lines on these parts so razor sawing was not possible unfortunately. There’s only one real way to get these bits off and that is to repeatedly score or cut down into the plastic with a fine pointed modelling knife blade, following the curved edges of the Tassets over and over until you finally begin to come through on the inside. To make it a little easier, once the grey plastic interior begins to show a thin whiter line, which is the stressing of the plastic from the cutting action, you can then score along that line from the inside to finish off the cut. In the second photo the left hand Tasset has finally been cut away and the moulded on strap has been sanded down flat with very fine glass paper. Also seen here, and in Photo 3, is that the Bevor strap has also been sanded away. After I took these photos I hit on the idea of first drilling out little pilot holes where the strap rivets will be before sanding the straps off – that way I’ve still got the accurate location points for the replacement ‘3D’ straps after the original moulding has been removed! Also in Photo 3, notice the ‘dimpled’ surface around the armpits – this is the kit representation of the mail (or maille in the old French), this is one of the areas, which is (hopefully) going to be improved further down the line. Photo 4 illustrates the point at which both of the Tassets have been removed, it also highlights one of the very few omissions that Imai made in this highly detailed kit! The box top art correctly shows the Tassets each hanging from two leather straps but the kit only has the inner one moulded on! You can make out two tiny holes drilled into the upper edge of each Tasset in this photo, one is in line with the moulded strap and the other marks where the missing strap will eventually be added in. The top part of the straps are still visible here on the lowest Fauld, I then drilled out the raised rivets on those and sanded off the moulded straps completely. As you’ll see later in this section, the sanding didn’t stop there!Blink Photo 5 shows the other half of the torso with the more complicated backplate section. The longer rear leather strap from the Bevor to the rear Placard is clearly visible here and just like the front one, this one’s got to go too! If you look at the very bottom of the Fauld plates you can see another two moulded on straps – these are holding on the very lowest plate which, unlike the ones above is a completely separate piece which ‘hinges’ on those straps. Just like the Tassets at the front, this section also has to be scored over and over to remove it as well, as shown in Photo 6. This same piece is shown inverted in Photo 7 in the process of having the ridges removed from the inside. As the plates are moulded in one piece, the stepped ridges on the outside are replicated on the inside and need to be sanded down. As you will see in the next instalment however, in this particular case I needn’t have actually bothered with this! Coming back to the single moulding again, this is where a little problem with the lowest Fauld plate rears its head. On the real armour, the plates are slightly overlapped which is fine on the upper rings but if the lowest sections are removed then the one above is now shorter than it should be (the underlying overlap having been removed as well!) This means that both front and back lowest plates need to be re-made so the ‘loose’ bits can be strapped to them, (don't worry, it gets clearer in the next post!) In Photo 8 the lowest front plate has been covered with masking tape to mark out the replacement. You can just make out the actual bottom of the plastic original through the tape, the real bottom is just about level with the two brown felt tip lines in the middle and then running parallel with that point to the edges. Fortunately there is enough depth in the moulded ridges to run the felt tip along to mark the curvy top edge. After the tape had been cut to size it was stuck down onto the material from which the new pieces of armour were to be made as shown in Photo 9 – a washed, cut down and rolled flat Tescos Tuna tin! This is actually the outside of the tin, the inside being an anodised gold colour. It’s a real pity this will have to be primed and silver foiled later – it makes a lovely steel effect on its own but I’ll have to keep all the metal work looking the same for continuity. With the tape stuck down I then used the modelling knife blade to carefully score around the shape ending up with the marking shown in Photo 10 ready to be cut out with a good pair of quite thin scissors.
In the second part of the torso re-styling, the tuna tin armour is cut out and the blacksmithing it into shape begins!Blink
Robin.
#24 Posted : 07 March 2016 12:14:21
Interesting stuff Robin especially with the names of the various parts of the armour? I assume the modern word 'placard' carried on through history from back then to be used for the common metal plates used in machinery and the like nowadays and which still means a type of metal plate? Tasset is a familiar word too and I believe is used to describe the so called individual plates on the DeAgostini Samurai Armour model?
Love your skill and bravery in dissecting the suit and also the use of the tuna tin metal is a stroke of genius, which will look very realistic and very 'in scale' and yes, I agree, a real shame that you'll have to prime and foil the plate afterwards to match the rest? You could of course start all over again and just keep Freddies' head and handmake a complete set of armour from a years' supply of tuna I suppose, then you could keep that nice 'steely' look!? Laugh Flapper Cool ThumpUp
Looking forward to seeing some of your blacksmithing my friend!? I reckon the rounded end of a 'ball-pein' hammer would make a useful anvil for that? Just clamp it in a vice and use a small modelling or planishing hammer to do the shaping and the job's a good 'un? Are you intending to have real leather straps on this and metal buckles as well - that'd look supercool I think?
Well done again Robin, really enjoying your work and yes, I'm still reading!!
#25 Posted : 10 March 2016 23:31:12
Many thanks for that Kev, I've learnt something now as well, never knew that metal plates in industry were called placards! (I've also since learnt that that part of the armour can either be called a Placard or a Placart - just regional European variations!)
You're right about the Samurai armour containing lots of Tassets, in European armour the tassets became the name for the extra 'add-on' plates whereas in the Japanese and Chinese suits of armour it was used to describe the individual bits of metal from which the armour was constructed. In Europe that style of armour would have simply been called a 'Coat of Plates'
I like that idea of real leather for the straps, at the moment I was planning on making the straps from the decra-led strip but I do have some offcuts of various leathers here somewhere - if I do find them I'll try slicing it down to scale thickness and see how it looks. The buckles are indeed going to be scale metal ones, I've just spent the entire evening trying to get them made out of brass wire - result: 3 good ones!
Many thanks as well for the comments about the tuna tin but the real genius should go to Stevie-o, I got the idea from his brilliant 'Downed Zero' diorama where he used beer cans to create the destroyed wing tips!Blushing
Oh well, back to the soldering iron!BigGrin
Robin.
#26 Posted : 13 March 2016 22:39:21
Hi All!
Firstly a quick apology for this instalment, there should have been two pages of photos and accompanying text instead of just the one today. Unfortunately (or very fortunately for Mum), I've spent the whole afternoon laying on my side under the kitchen sink unit putting in new pipework and a new lever operated mixer tap which will be better for Mum's weaker grip through arthritis - it all went well after much 'altering this and changing that' with only a couple of drippy nuts to tighten up under full pressure, but as you can imagine I didn't get much opportunity to complete the diary page for today! (Plus I'm feeling as stiff as a board too!)Blink Talking of boards, just got to get a new melamine board to replace the shelf under there now - the old one dips about three inches in the middle!BigGrin
And Kev, you weren't far off in saying 'start from scratch' when I made the first few sections of armour I had this wild idea about getting a cheapo 'action man' doll thingy and making a Roman Legionary bust, that would be in 1/6th scale and a bit easier to cut the pieces out too!Cool
OK then, in Photo 1 we have the basic set of tools I used to create the first piece of the Fauld plates – the front section. Kev was almost right in suggesting the ball pein hammer, this is a very similar hammer as seen here but not used in the way Kev was thinking! As these Fauld plates are essentially flat sheets bent into a simple curve, and the tuna tin metal is very soft and malleable, I was actually able to bend the metal into the required curve by pressing it against the wooden handle of the hammer and firmly smoothing along the sheet with my thumb to form the curves. The ‘business end’ of the same hammer was used in the traditional sense to form the raised line in the centre, which matches up with the moulded plates above. After marking the centre line in felt tip on the reverse, the wood chisel was given a solid ‘thump’ to impress the soft metal, creating a raised line on the front face (apologies to all competent wood-workers here – I know this is a sacrilegious use for a chisel!)Blushing Once that was done, the flat spatula type tool seen beside it was used as a punch with the hammer to tidy up the outer edges of the raised line by tapping it down from the exterior side. The finished plate can be seen in the foreground and also resting on top of the kit torso in Photo 2.
Photo 3 is a close up of the same torso piece with the new plate removed. You can clearly make out the top outline of the reduced bottom plate, compare the bottom edge with the previous photo and you can see how much of the kit part was actually behind the two moulded on Tassets! The line of little drill holes marks the top of the new plate location. You see, because the torso has part of the bottom plate moulded on I can’t just glue the metal replacement straight on top – to maintain the overall thickness of the overlapping plates, the moulded one now has to be sanded down smooth, level with the next one up! Once that plastic has been removed, the drilled holes will mark the upper edge for the new metal plate to be super glued up to. Photo 4 illustrates the rear half of the torso together with it's replacement bottom plate. Again, that moulded bottom Fauld will have to be sanded away to fit the metal one in place and the single hole seen here marks the position of the strap for the ‘hinged’ lowest plate.
Which brings us to that very same plate! After constructing the front and back Faulds in the tuna tin metal, I was very pleased with the overall effect. The problem came when I offered up the kit part shown in Photo 5. The plastic part now seemed far too thick compared to the scale thickness metal parts – there was only one thing to do and that was to make an entirely new hinged-section too!Blink Masking tape was stuck over the plastic original and trimmed back to fit the size and shape. Once satisfied with it, the tape was removed and pressed down onto the tuna tin as shown in this photo. After carefully scoring around the tape, it was removed and I cut out the shape from the tin (the hardest parts of the cutting out are the curved sections, of which there are many! I find it much easier cutting a curve from right to left so sometimes it was easier to cut outside of the scored line, remove the entire piece from the larger metal section and then make right to left cuts from whichever side was easiest, right way up or upside down!). Finally in Photo 6 we have both the lower Fauld and the hinged plate below the plastic rear torso. The ‘bum’ depression was created with the hammer and another one of the stainless steel tools shaped like a flat spear head (I believe the actual set is for wax sculpting but they’re great for Milliput sculpting too!) This photo was taken right after the first ‘bashing’ session, the dents and depressions have since been slightly cleaned up although the two side dents will be completely covered by the suspension straps anyway.
The second part of this instalment will follow in a day or so (when my back is working again)BigGrin and I’ll explain what the lines of drill holes down the Faulds are for!
Robin.
#27 Posted : 16 March 2016 17:33:04
And now for those holes!
Looking at the original armour as shown in Photo 7, you can see a line of small brass rivets running down the plates of the Fauld. I believe those rivets are what actually support the armour and they are connected to a thick leather strip running down the inside of the steel plates. There are four such strips, two at the front in the location shown here and another two on the rear, slightly further back around. The basic design of the strap system is shown in Diagram 8. In actual fact I’ve put the steel plates in upside down! They should be overlapping on the inside, not the outside, but the principle is the same!Blushing
The first job was to mark out the location of the four sets of rivet lines as shown in Photo 9. This was first accomplished with a pencil line followed up with a piece of masking tape stuck down along those lines as seen here. A small hole was then drilled in each plate; I think it’s about 0.8mm in diameter. After the armour has been gilded and washed, a tiny brass pin will be inserted into each hole to form the rivets, a ‘dry run’ is shown in Photo 10. These are currently my smallest, finest brass pins, I’m not exactly sure if they came with one of the ship kits or whether I bought them in the Model Shop, even these are a little over-scale so I’ll either have to find a pack of even smaller ones or possibly try to get them to fit in a drill chuck and grind the pin-heads down a little (I tried doing one by hand in the pin vice on a diamond dust file but only succeeded in grinding the entire head off!)Blink
Photo 11 illustrates the first ‘awkward’ decision I came to in the build – the two halves of the torso are supposed to be glued together encasing the shoulder pins for the arms. Built according to the kit instructions, this would give the arms a little bit of movement in both rotation and up and down. The pose I’m hoping to achieve for Frederick is a little more ‘energetic’ than this however, and since the arm halves have to be glued together over these shoulder pins I would have to construct them attached to the torso from the start. It is going to be far easier to make up the arms as separate components and then glue them into the shoulders so I decided to leave these two moveable pins out. The inner locating rim will be filed off leaving me with a simple peg to be glued in once the arms are completed. Finally in Photo 12 we have the torso glued together at last. Once all the finicky filing and sanding has been done I’ll be able to superglue the new metal plates into position and then work out how two of the essential ‘up-grades’ to the torso will be constructed – the securing straps and the brass hinges.
Until then (and some head scratching) Happy Modelling to you All!
Robin.
#28 Posted : 18 March 2016 10:35:35
A couple more very interesting updates from you Robin, some great reading and may I say some even greater modelling skills on show here - very well done that man!! CoolThumpUp
Can I just say (and I'm not out to upset any other members here, just an observation on my part) that I do wonder sometimes why you aren't getting more comments from fellow members on this build, and can only assume that suits of armour and knights of old aren't most peoples' cup of tea and each to there own of course?! Added to which, I think some may be put off by the length of your posts, which I know has been mentioned in the past, but it has to be said that for me, that is the part which is most interesting and in my view totally necessary in order for the reader to understand what is happening at each stage? To me, this really is a fascinating build and involves a lot more work than most mainstream modelling subjects would require, so I take my hat off to you mate and can only say that more people should read your updates and make comment - I feel they really don't know what they are missing?!
All the best Robin and keep those updates flowing, looking forward to the next one already!! Cool Cool Cool ThumpUp
#29 Posted : 27 March 2016 20:12:03
Grateful thanks again for those kind words Kev!Blushing Blushing I think a lot of it is down to the theme of the model - there certainly isn't a glut of medieval subjects on the site at the moment!BigGrin
Personally that's a pity as the Ancient / Medieval periods are my favourites - there's such a wide range of subjects that can be covered, from Classical Greece and Rome through Viking, Norman and Crusades right up to Richard III. If only the injection plastic kit manufacturers would give us more to work with! (What I really mean is more to hack to bits!)Blink
I'm very much like yourself with regards to the text - a quick "I made this up and stuck it to that and Hey Presto" would be much easier to put together (in every sense!) but I love reading about the 'nitty gritty' of exactly HOW it was made! The more I can understand how someone else came up with a solution to a problem, the more ideas I can come up with to create something for my own needs! The simple and elegant solution to the square buckle shown below is a perfect example!
Anyhows, I do try to keep the wording down (sometimes BigGrin ) but on occasion 'A thousand words are worth a couple of photos I couldn't take!!'LOL
Since typing out this entry I've sent off for a leather offcut on Ebay to try out 'real leather' straps - I can't keep secretly removing the insides of Mum's purse!Blushing
Buckles and Hinges Pt 1: The Buckles
The biggest problem I encountered at first was trying to form the brass wire into rectangles small enough for this scale. I tried using every mini pair of pliers I had but even the smallest and finest still wouldn’t allow me to bend accurate and even shaped rectangles. The answer came, as many others have done, whilst searching for ready made buckles on the internet. I came across an explanation by another modeller who was making up seat belt buckles for 1/35 scale vehicles – he was using fuse wire instead of the 0.5mm brass wire used here but his method of obtaining the initial squares was so obvious I still feel pretty stupid for not seeing it before! Instead of trying to form the shapes with pliers, all you have to do is bend the wire around a suitably shaped former – like I said – so obvious, but as is often the case in modelling, tunnel vision sometimes takes over – once I’d decided on using pliers I became fixated on that method alone!
Photo 1 illustrates the simple method itself. The other chap had used a square plasticard core but to form brass wire I needed something as strong as the brass – ie, more brass!Blink I used three different sized brass square rods for the buckles, the two larger ones had a hole drilled through to start the coil off with, the thinnest one was too small for that so I simply gripped the start of the wire against the rod with pliers. The brass wire was wrapped around the rod, keeping it as tight as possible before cutting off the start end and sliding the resulting coil off the rod as shown in Photo 2.
This first batch was then snipped up through the middle with my finest wire cutters to create the set of buckle shapes as shown in Photo 3. As you might notice, a couple of them are not exactly ‘square’, I later refined the process, squeezing the coil against the rod to even up the sides and then cutting the coil off by slicing down the middle with a thin cutting disk instead of using the wire cutters. The subsequent sets were better shaped! The next step was to create the central bar over which the eventual strap will pass. This was probably the most exasperating task so far on this build (with the possible exception of the chain mail experiments to date). The bar had to be cut to such an exact size that many ended up going just a hair’s width under size, which made them useless! It was a case of cutting just oversized and then grinding down each end of a 2mm? Piece of brass until it could ‘snap’ into position, holding itself in the middle until I could fix it with a tiny drop of solder as shown in Photo 4. More than once I got it just perfect only for the ruddy thing to ping out of the tweezers and vanish into oblivion! The perfect fits were snapped into place using the bottom of the large cylindrical aluminium knife handle and then the whole thing was gripped in the very tip of the spring tweezers for soldering (and another great opportunity for the ‘pinging fairy’ to strike!)Cursing Three finished buckles can be seen in Photo 5 alongside the 0.5mm wire used to form them, whilst in Photo 6 you can see the growing collection of buckles – there are three sizes here, the smallest ones are for the side straps of the breastplate, faulds and tassets, the middle sized pair are for the straps securing the helm to the bevor and the largest one is the main buckle for Frederick’s sword belt. There is another set of buckles to come yet – the ones for the tightening straps on the arm and leg armours – these will be even smaller!Blink
In the next part of this section – Forming the Hinges.
Robin.
#30 Posted : 27 March 2016 23:36:23
More amazing work Robin, you never cease to surprise us with the detail you apply to your builds..... Drool Drool Drool .. Brilliant.....
#31 Posted : 28 March 2016 01:15:38
I fell a little behind with this but have just caught up and wow Blink
It never ceases to amaze me the skill that goes into your builds a well as the endless patience!
The subject matter I'm sorry to say isn't something that appeals to me, however saying that doesn't stop me enjoying and admiring your build Cool
#32 Posted : 28 March 2016 12:03:28
Hi Robin.
Great start on your build , Look forward to seeing your progress IanBigGrin
#33 Posted : 03 April 2016 16:57:08
Many thanks to Alan, Dave and Ian, much appreciated as always!Blushing Modelling is such a vast ranging hobby - far wider than most I should think with everything from dinosaurs to sci-fi (two of my personal favourites right there!)BigGrin To me, model cars and trucks are the least appealing although even then, chuck in a couple of '50 cals and turn it into something out of Mad Max and I'm in!BigGrin Cool
I've split the second part of 'Buckles and Hinges into two parts - mostly because the leather turned up and I've gone back to the buckles again! Anyhow here's the first bit!
A test fit of sorts is shown in Photo 7 running on from last week with three of the side strap buckles placed on the torso, whilst the final shot for the buckle collection is seen in Photo 8. You can see those smaller silver buckles at the back of the group. These were made from a smaller 0.4mm silver plated wire which I found in the local Hobbycraft store – a 20m roll for just £2 – not bad at all considering the ebay prices were very similar! I did come across a slight problem here though, I assumed the wire was silver plated brass but when I sanded down the solder joints I discovered that it seems to be silver plated copper instead. I don’t think I’m going to be able to get the central bar to fit inside these which leaves me with a decision for later – do I solder them, sand them off and then paint them back to silver or simply squeeze them into shape and leave the silver plating intact? Time will tell on that one. Note also at the top left an initial trial using a tiny bit of black leather inserted through one of the brass buckles. This is a more supple leather than the off cuts I’m still looking for and was consequently more difficult to slice down to scale thickness. It’s not bad though, but I will still try and get some tan coloured leather to try out before I decide how to make the straps for real.
And now on to the brass hinges!
I did a lot of thinking on these hinges – I considered trying to fabricate them out of actual thin brass sheet or strip, the problem is, they are so ruddy small that it’s almost impossible to hold them with anything in order to file or sand the ends smooth! In the end I realised that I already had a good facsimile of this brass right in front of me – Mum’s old eye ointment tubes again! The same material which I had used for corrugated panels, was already plated with a gold/brass finish on the other side! (As is shown in Photo 9). The first task was to introduce a line of ‘rivets’ into the opposite silver side using the good old circular saw blade from the rotary tool set as illustrated in Photo 10. What I haven’t shown here for clarity is the six inch steel ruler, which I first placed in position to roll the saw blade along. With the first line in place, a second was then embossed a couple of mm inside the first. This is shown in Photo 11 with the tube metal now brass side up showing the rivets in relief. With the sheet upside down again, the steel rule was used once more to scribe a line or channel between the two rows of rivets as shown in Photo 12. When that was done, we then have a strip of ‘hinges’ with the central bar or pivot running down the middle as in Photo 13. Photos 14 and 15 look pretty similar – this is because the thin coat of Humbrol Black Enamel Wash doesn’t appear as dark in the photos as it does to the human eye! When the hinges are finally glued onto the silver gilded armour, I’ll probably give them another wash to emphasize the shadows further. All that remained then was to slice the hinges off the strip, each one having two sets of rivets as shown in Photo 16. The cutting process does flatten the ends of the central bar in some cases but this can be remedied by carefully re-embossing the channel with the large sewing needle – and finally for the hinges, Photo 17 illustrates the set of five, temporarily placed on the left side of the armour where they will be glued after the silvering and ‘steel’ washing is complete.
In the meantime, my leather off cut has arrived from ebay! It is shown in it’s entirety in Photo 18 and is a 8 x 2.5” piece of “Warm Beige” which worked out at about £1.30 or so. Unfortunately it is also of the ‘soft’ and pliable type which, from my point of view, is a little more difficult to work with as I mentioned compared to the stiff type (like briefcases are made from for example). As I still can’t find my old pieces of leather, I’ll have to go with what I can find! I do like the colour however, I think it’ll go really well up against the steel plates later on. As you can see from the close ups in Photos 19 and 20, the leather is way over thickness for this scale and in the next part of this section I’ll show how the initial trial straps were formed. In working on them and after some further web research, I discovered that there was indeed an easier way to accomplish what I’ve done so far (I thought there would be!)Blink So I’m now waiting for another delivery from China – more on that in the next instalment!
Until then –Happy Modelling to you All!
Robin.
#34 Posted : 10 April 2016 16:07:44
Carrying on from the last instalment and the introduction of the oversized natural leather....
The basic technique for turning the standard leather piece into scale sized straps is shown in Diagram 21. From top to bottom we start with the full thickness leather as shown earlier. The first task is to shave away the fibrous underside of the leather to leave as thin a layer of just the top surface as possible, as illustrated in Photo 22. In this case (more of a trial than anything else) I used a brand new safety razor blade as shown in that photo. What’s really surprising is the amount of material that has to be removed as you can see here!Blink After I had completed this trial, a little further searching on the web revealed that this process is called “Skiving” (Sky-ving), I have to wonder if the term ‘skiving’, ie, to remove thin layers of something gave rise to the slang term ‘skiving off’!Blink Anyway, I since learned there are actual tools available to perform this task called Skiving Knives (as well as very expensive Skiving Machines as well). There are two basic types, one shaped like a paint scraper for larger areas and another a bit like a vegetable peeler. The peeler type is available on Ebay (from China) for less than £2 (free p&p) so I’m putting off any more strap production for the time being until that particular item arrives and I can try it out – you can also get them from UK suppliers, but why pay around £7-10 when I can wait a few weeks!BigGrin
After the leather has been suitably thinned down the next task is to slice it into thin strips the actual width of the strap required, (third piece down on the diagram). Once that is done it’s time to thread the strip through the brass buckle constructed earlier. Passing the strip through the first section was easy enough (sort of) but I found that passing it down through the other half was much more difficult and required the inserting end to be cut down, both to a ‘V’ shape as shown on the diagram and also by slicing off the underside even further as shown in the ‘bubble’.
With the leather strap now threaded through the buckle, the longest part was cut off as illustrated in the fourth section down. Once removed, the ‘buckled’ part was given two pierced holes using a large sewing needle, either side of the buckle, into which will later go the locating brass pins. The remaining cut off section was then given a series of similar holes to form the protruding part of the strap, which sticks out beyond the buckle as shown in Photo 23. This section was then super glued up against the brass buckle after first slicing off the underside to give the illusion of the strap coming up from ‘under’ the buckle itself (the angled end shown in the diagram). The completed strap is shown against the traditional penny in Photo 24.
Using that needle to pierce the holes was easy enough but quite hard on the fingertip doing the pushing! The obvious answer (discovered millennia ago by the female of our species) was to use a thimble!Cool Haven’t got one of them however, so I improvised a more controllable handle for the needle by cutting off a couple of inches from one of my ‘The Works’ paintbrushes, drilling it out and pushing the needle down the hole as shown in the before and after shots of Photo 25 – it’s much easier to grip the needle now (and more accurate as well)!
Finally for this instalment, Photo 26 shows the three straps pushed into place using the brass pins on the right hand side of the torso. They need a little trimming down to get them to a similar length and the top one will need to be re-done as the tiny little cross bar broke away from the buckle during the insertion process but it gives a good idea of what the finished effect will be with the ‘excess’ parts of the strap sticking out quite a bit as in real life, unlike the moulded originals which were flat to the surface (and much smaller too). Those brass pin heads also have to be ground down into a smaller diameter too.
As I said earlier, I’m now waiting for the Skiving Knife to arrive before I carry on with the rest of the straps, of which there are many, on both the arms and legs for example.Crying
In the next instalment, Frederick’s left arm will be getting the surgeon’s attention (and the blacksmith’s too!)
Robin.
#35 Posted : 17 April 2016 21:08:16
Before I begin hacking up Frederick’s left arm, here’s a quick example of how this type of jointed armour actually works. Unfortunately I don’t possess a piece of arm protection in this style (mine is a two piece shoulder and forearm with no elbow protection) but I do have leg armour with the same riveted ‘lobster-plate’ joint as shown in Photo 1 which will serve the same purpose. Apologies for the dull finish, I should have polished this up months ago!Blushing Photo 2 illustrates the moving joint system with the straight limb shown on the left and the flexed or bent limb on the right. Most of the movement is taken up with the knee (or elbow) piece, and the riveted plate below it. The knee ‘bowl’ is called the Poleyn but the corresponding elbow piece would be called the Couter. If you compare the Couter and adjoining plate in the two photos you can see that there is more of the plate showing in the bent photo illustrating how the Couter has rotated up and back from it. Both of those plates are capable of hinging and in the highest grades of armour the movement in both would probably be about the same.
Photo 3 shows the three parts of the main left arm (there are another three parts later to make up the gauntlet). As you can see everything is moulded ‘in-situ’, and despite the moulding being of excellent quality, a lot of it is going to have to be replaced in order to bend the arm. Photo 4 shows the movable shoulder joint in place on the inner peg. If following the kit instructions to the letter, those two rims on the plug would have been used to trap the joint between the two halves of the torso giving the arm some movement at the shoulder.
In Photo 5 we have a close up view of the elbow joint itself. There were two ways of going about altering the joint, I could either attempt to carefully pare away under the protective ‘butterfly’ plates seen here and then, equally carefully try and cut into the edge of the Couter to salvage as much of the fine detail as possible or I could simply hack off the parts mentioned above and start from scratch. Looking at Photo 6 you’d probably think I went for option 2 but in actual fact I did make an attempt to use the butterfly part! Despite my best attempts, once I began to cut or slice under those ‘wings’ the plastic simply started to curl upwards and eventually cracked away from the rest of the arm. With one side lost, there was no point trying to save the other so after filing down the rivet and replacing it with a drill hole to mark the spot the rest of the butterfly was rapidly removed with blade, grinder and file as shown here. Photo 7 is actually out of sequence! Before attempting the salvage option I took the precaution of marking out the shape of the butterfly using masking tape and a permanent marker pen as shown here (just in case!) As the attempt was a dismal failure this was just as well and the masking tape template was then used to cut out a replacement part in the tuna tin metal. This was then drilled through to take an Amati ‘very fine’ brass pin as shown in Photo 8.
The real butchery begins in Photo 9! The Couter has been sawn through on the inner line beside the ‘dome’. In retrospect, this was a mistake as I later realised that the first riveted plate beside the dome isn’t in fact a separate piece but is actually part of the dome. This meant I’d have to do some ‘repair’ work later on, this error hopefully won’t be repeated on the right arm!Blushing The same stage is shown from the other side in Photo 10, the two arrows indicate the remains of the outer riveted plates – these will have to be sanded away smooth to the surface to provide the under-surface which the outer plates (to be made from the metal can) would be sitting on. Also due for removal is the moulded on strap at the bottom left to be replaced with a real leather one later on. The moulded rivet was again filed down and replaced with a marking hole for a brass pin. I gently flexed the arm into a more bent position hoping that the Couter might stay where it was but in the event it did part company on one side so I removed it completely as shown here for easier cleaning up, in Photo 11. Also shown here is a section of brass rod, bent into the angle at which the arm will be ‘set’. What is probably obvious in the pic but wasn’t to me until I tried to fit the rod in, is that it was far too long to go into both halves of the arm at the same time! It was consequently reduced down in length until I could just get it in, at which point the arm was super glued to the rod (by dribbling the glue down inside) and finally, the Couter was also super glued to the ‘elbow’ of the rod and also liquid poly-glued back to the edges of the plastic armour as seen here in Photo 12.
In the second part of this section the metal armour plates are formed to fill in the gaps in Frederick’s arm, the repair to reform the Couter is achieved and the armoured gauntlet receives it’s own alterations.Blink
Robin.
#36 Posted : 17 April 2016 22:05:06
Hi Robin.
More amazing work, Keep the pictures coming. Ian Cool BigGrin
#37 Posted : 24 April 2016 16:40:03
Many thanks for those kind words Ian! Blushing In this installment the new armour sections finally begin to like actual armour!BigGrin
Photo 13 shows the first of the metal replacement plates under construction. A strip of about 2.5mm has been cut off the tuna tin metal and was then simply pressed around a suitable wooden dowel to form it into a curve. After drilling the rivet hole in the starting end, the now curved strip was offered up to the plastic arm and the other end marked in with a thin permanent marker as just visible in this photo. The position of the other rivet was then marked in and using a hard nail, a small punch mark was hammered into the strip to aid drilling out the second hole with the pin vice and drill bit as shown here. (Keeping the darned thing still to be hammered was not easy!)Blink
Once the second hole was drilled out, the strip was cut off along the mark and the completed strip placed onto the plastic arm as shown in Photo 14. As with the full size armour, the effect of forming the strip around the dowel creates a sort of ‘sprung steel’ and the new metal plate will hold itself in position whilst a small amount of thin super glue is applied around the edges with a cocktail stick, ‘wicking’ itself under the plate to fix it in position permanently. The composite Photo 15 shows the first three plates in position following the same procedure as outlined above – the first plate now has its overlapping companion on the wrist end of the arm and the first plate has been fitted on the shoulder end as well. As I said before, it’s a real pity that this lovely ‘steel’ effect has to be silvered over to tie all the metal and plastic sections together later on! Photo 16 is almost a repeat of 13 with the last of the articulated plates sprung into place to be marked for cutting off. At this point, this was as far as I’d originally intended to go with the arm, leaving the rest of the armour as it came on the kit. The more I looked at it however I kept thinking why not try the upper arm section too? The thinking was ‘ it’s only a simple cylinder with no compound curves – how difficult can it be?’ In the end I had a go and, lo and behold, it was easy enough to do - I stuck a piece of masking tape over the plastic part, marked around the edge and then cut it out of the tuna tin before curving it into shape around a slightly smaller wooden former (a paintbrush handle in this case) so that the finished piece would be ‘clipped’ in place for gluing. The result is shown in Photos 17 and 18, the new piece stands out a lot more from the underlying layer than the moulded on original, something that will be far more convincing when the ring mail is added on much later. Also seen in these two photos is the thin layer of Milliput epoxy putty used to ‘fair in’ the new plates adjoining the Couter. This extra depth can be seen even clearer in yet another Photo 18 (I’ve only just realised the numbering mistake – too late now!)Blushing shown with the protective butterfly wings also temporarily back in place. The dimpled bottom layer will eventually be composed of individual metal rings – but not until some more Milliput application!Blink
Photo 19 (without the butterfly again) illustrates one half of the armoured gauntlet placed on the end of the arm to show how it fits on the end of the peg at the wrist. The two ‘tabs’ sticking up on the edge are just the sprue attachments which I hadn’t yet removed at this point. The lower arm is composed of these two halves together with a single piece hand insert which is shown in Photo 20 (front and back views) In the finished model, this hand will be gripping the handle strap of Frederick’s shield so a little more articulation is required from the fingers. The first step for this is shown in Photo 21 – the hand has been cleaned up from the slight amount of plastic ‘flash’ evident in the previous pic and then the fingers have been sliced off at the first and second knuckles which corresponds to the moulded strap. This strap is nothing to do with the shield however, this is the gauntlet’s own strap which secures the hand to the moveable articulated plates protecting the hand inside.
In the third part of this section, I'll be re-modelling that hand and beginning to silver leaf the gauntlet. As this is a completely separate piece, I can bring it to it’s finished condition now and then lay it aside until final assembly.Cool
Until then Happy modelling to you All!
Robin.
#38 Posted : 01 May 2016 16:12:14
Carrying on from the last post:
The previously sliced up hand is shown glued back together in Photos 22 and 23. Before gluing, the edges of the palm and finger sections were sanded back, angling down from the top surface as shown by the white sections in the diagram, (these were the parts removed in the sanding). Once fixed back together, this created a slightly more ‘cupped’ hand, seen best in Photo 23. Moving on to the armoured gauntlet itself, this is shown glued together and sanded smooth in Photo 24. It is worth noting that the left and right gauntlets are NOT identical! As in common with this period in armour design, the left hand armour is of a simpler design than the right. This gauntlet was designed to be used only to grip simple leather straps, – either the horse reins or the wooden shield hand-strap. As you can see here, the armoured section has only two parts; forearm and back of the hand guard in one formed piece with an articulated finger guard plate. Since Frederick will indeed be holding his shield in this hand there was no need to fabricate a new finger guard. His right hand however will be gripping his battle sword and that gauntlet has more moving parts for greater flexibility – not looking forward to THAT one!Blink
In Photo 25, the set gauntlet has had a wooden skewer pushed up into the wrist hole for a convenient handle to spray the piece with Poundshop Matt Black primer. Given overnight to dry completely, the next evening the inside and outside of the hand section was given a coat of thinned down acrylic size, left for 35 minutes and then the silver leaf applied to the surfaces as shown in Photo 26. This was then followed by the same procedure for the cuff section to complete the leafing as shown in Photo 27.
Stepping backwards for a moment, here’s one I forgot to put in earlier!Blushing Photo 28 illustrates the re-formed hand test-fitted back into the armour. It fitted fairly well here but it turns out that if you follow the instruction to the letter, some parts are designed to be fitted in when the two halves of whatever they go inside are glued together! This means that some parts of the conversion are going to be a little more difficult than I had originally planned!Crying The next part to come under this category will be the left shoulder armour or Pauldron – I’m still working on how to sort that one out!
After checking the fit, a length of plastic kit sprue was glued to the wrist of the hand to provide a convenient handle for painting and then the hand was sprayed matt black as illustrated in Photo 29. This was followed by the actual painting, which took a couple of days, allowing the base coats to dry completely in the process. The actual technique was as follows:
Over the matt black primer I applied two thick coats of Revell acrylic Wood Brown (382) with 24 hours between the coats. The following day I drybrushed over the glove with Admiralty Yellow Ochre acrylic and once that was dry I picked out the shadows along the strap, in the creases and between the fingers with Citadel Skaven Brown Ink. Finally, another drybrush of the Yellow Ochre mixed with Revell White acrylic to pick out the highlights. The final ‘worn leather’ effect is seen in Photo 30. The next step was to ‘replace’ the moulded leather strap with a real one as shown underway in Photo 31. A new strap was cut from the thinned down real leather and with the sprue handle gripped in the mini vice, a series of tiny drops of super glue gel were applied along the moulded strap before the replacement one was stretched around over the old one as shown here. Once the super glue was set (a matter of seconds) the excess strap was sliced off with the razor blade and the finished hand was re-fitted back into the armour as shown in Photo 32. (That 'temporary handle wasn't quite as temporary as I thought!)BigGrin
With the extra thickness of the leather in place, as thin as that was, this is where getting it to fit back became – ahem, ‘a little harder!’ Eventually it did fit back and I was able to permanently fix the hand in place by applying Revell Contacta polystyrene glue down through the small wrist hole (where the skewer had gone before) and allowing it to flow around the joint from below. The finished armour as shown in this photo and the last one Photo 33 actually looks a lot ‘grottier’ than it actually is – some of the shine was dulled down during the battle to re-fit the glove but it does really look like battle hardened steel away from the macro setting on the camera! In actual fact, much of this part of the armour is hidden away under his shield anyway, still its all good practice!
In the next instalment, I’ll be getting to grips with the shoulder armour to finish off this arm – more tin bending to come!Blink
Robin.
#39 Posted : 08 May 2016 15:35:53
Just having a Senior moment here! I couldn't work out why I couldn't paste the latest text into the diary - suddenly realised it might have something to do with the fact that I haven't copied the text yet!! Ho-hum!
Anyhow...
In Photo 1 we have the two half pieces of the left Pauldron, this is the articulated shoulder armour. In the following centuries, the Pauldron would itself be protected by a second layer of steel, a single large plate called the Gardbrace but in Frederick’s time the Pauldron was considered sufficient. The kit parts have been glued together in Photo 2 and are shown together with the first replacement steel plate. This was formed from the tuna tin metal by first sticking a strip of masking tape over the bottom-most plate or Fauld, marking the edges of the plate with a thin permanent marker pen and then sticking the marked tape down onto the tuna tin and cutting out the design. The resulting metal copy was then carefully bent into shape by forming it over a variety of wooden paintbrush handles with the armpit ‘kink’ bent into the metal with a pair of long nosed electrical pliers. This first section is then shown placed over the plastic kit original to check the shape in Photo 3. Note the pre-drilled ‘rivet’ hole in the ends, which will take the smallest brass pins to secure the individual parts together.
The second plate has been formed in the same way and temporarily fixed with the brass pins in Photo 4, the masking tape is marked along the upper edge and sides, following the kit contours, but is continued down about halfway under the plate below to create the ability to articulate without leaving dangerous gaps in the armour. Plate number three is attached in Photo 5 and now you can begin to see the shape of the lower part of the armour taking form. I found it easier to drill the rivet holes in each successive layer after it had been attached to the one below – this way the holes can be made to line up a little better!
I have now arrived at the first dilemma with this part of the armour. There are two ways I can proceed – the first involves trying to make the entire Pauldron from scratch using the tuna metal. If I can achieve this, this would be my preferred course of action as all the parts of the shoulder would be uniform in thickness and appearance. The problem is, the next section, the largest part of the shoulder is not as easy to produce. Unlike the other plates above and below it, which are basically simple curves (with a ‘kink’ in the lower ones), the central piece is far more complex with compound curves and a sort of ‘expanding’ effect under the armpit at the front. Instead of simply bending the metal around rounded wooden formers, this part will need some bashing with a hammer to get it right!
The second method will be to form the upper and lower plates out of the metal and to employ the kit part to provide the central section. This has two problems – the first is the thickness of the plastic part – irrelevant on the bottom section as those metal plates fit over the top of the plastic (which will of course require the original lower plates to be sanded down smooth) but on the top section the new plates will be fitting underneath the plastic so the plastic part will need to be thinned down dramatically as much as possible. The second problem is shown in Photo 6 – in the kit, the Pauldron is designed to fit over the arm using the sockets seen here. In the next instalment you’ll see the arm ‘fitted’ in place (not really though as I’ve sanded off the locating lugs!) In reality, the Pauldron is secured by a leather strap under the arm with another one at the top linking the Pauldron to the breastplate/backplate. If I do use the kit part I’ll need to grind down those sockets completely so that the shoulder piece just ‘sits’ on the arm allowing the arm to rotate inside it. I’ve started bashing the tin around this weekend – so far so good but wish me luck and we’ll see how it went next time!
Robin.
#40 Posted : 15 May 2016 16:08:35
Left Pauldron Part 2:
As promised previously, in Photo 7 we have the inside of the kit Pauldron showing the jointing system used to join the arm to the torso. The two moulded sockets seen horizontally in this shot would have enclosed the two lugs on the end of the arm allowing the arm to swing up and down. At the same time the ‘drum’ at the end of the arm which fits between those sockets and which is not glued would have allowed the arm to swivel to the front or back. As I mentioned, I’ve sanded off those lugs so the arm joint is simply resting in that socket at the moment. Once the arm is cemented into the torso that entire joint system will be encased in Milliput to mould the ‘proper’ armpit area and the Pauldron will be resting in place over the top with it’s new leather straps.
Photos 8 and 9 illustrate my ‘Medieval Smithy’! The ‘heavy’ work was carried out on the ball pein hammer shown here securely held in the bench pillar drill work vice. The hammering was performed with the little jeweller’s hammer although, for the right hand Pauldron I may well try a different technique and try to ‘roll’ the curvature into the tuna tin metal using cylindrical metal knife handles to see if the result is smoother than bashing the hell out of the metal! The finer work was accomplished on the little jeweller’s anvil also shown in the photo. I found it very difficult to hit the metal hard enough without the anvil moving under the impact so in the end I simply fastened the anvil into the work vice in place of the hammer as shown in Photo 9. Also employed, as shown in Photo 10 was a little mini vice with a section of large dowel gripped in it. This was used both in the initial bending of the plates and also as a convenient stand into which to drill the rivet holes at the ends of each separate plate as seen here. Now we come to the most complicated of all the plates – the biggest one shown here outlined in yellow in Photo 11. This one is a nightmare, with a gentle curvature plus a slight kink at the bottom on the back side, and a compound ‘expanding’ bulge on the front side! As well as all that it also has a slight curve inwards at the top edge! The masking tape template is shown below although in the case of this one, there was a lot of extra trimming carried out during the fitting in place, especially along the top edge where about 2 – 3mm was eventually removed.
Surprisingly, despite all the measuring, altering and scissoring, it went together pretty well and is shown almost complete up against the plastic original in Photo 12. Only the final top curved plate is still to go on (again shown with the yellow outline on the original). That final piece; the smallest of the lot was probably almost as difficult to put in as the big hammered one in the middle – by the time I got to that last one I was running out of space for the rivet holes and it got so tight that pressing the brass pins through actually split the metal on the next to last plate requiring the final one to be super glued in place. This is the only one that doesn’t therefore realistically articulate!
The actual process of gluing that final piece is shown from the underside in Photo 13. After securing the piece in place with a pair of spring tweezers just visible on the bottom right, super glue was ‘dribbled’ into the inner overlap with a cocktail stick where capillary action then drew it into the joint. In actual fact I had to do this twice as the initial join gave way during some over-enthusiastic final shaping! The second attempt seems to be holding so far!
The last bit that needed to be added was a small rim around the edge of the lowest plate. This is apparent in photos of the real thing and is just noticeable on the plastic kit parts too. I did have a go at soldering the copper wire onto a scrap piece of the tuna tin bent into a representation of the lowest plate but although the copper was fine to cover in solder, the metal just wouldn’t accept it at all. I think this is due to the lovely ‘steel’ effect being an electroplated covering as I discovered soon after that the metal is actually a bright silver underneath the steel (there must be a fair amount of iron in it too as it’s very magnetic when it comes near the stainless steel fine tweezers)! I finally managed to fix the ‘proper’ rim in place by shaping it around the bottom of the armour with an extended overhang at each side, which was held down to the work surface with masking tape. Holding the armour flat to the surface I could then dribble super glue between the copper wire and the metal plate, eventually fixing it in place. Photo 14 shows the Pauldron in the position it was held in to glue the rim whilst Photo 15 shows it in the fully extended position. The only drawback to the super glue was that the glue left a slightly ‘lumpy’ appearance in the gap between the copper and the metal. This was reduced right down, by going over the copper and the glue joint with the rotary tool and a circular wire brush. It was during this ‘burnishing’ task that I discovered the true finish of the tuna tin metal.
Finally, in Photo 16 we have the finished Pauldron tacked in place on the kit torso. The brass pins acting as rivets will be replaced later with new ones with their heads ground down smaller to scale and the top part of the armour will be fixed down by a leather strap which comes from under the top to disappear under the neck armour or Bevor. There was one last hole to be drilled after this photo was taken, right down near the rim in that ‘kink’ shown in Photo 14. The securing arm strap will go from that kink around to the bottom most rivet on the front face. After I have made the twin set for the right shoulder the two sets will be dismantled and the individual plates silver gilded before reassembling with the smaller brass pins. The ‘bluing’ wash will be applied once the whole thing is fixed back together again, I'm hoping that the wash will act as a sealer, fixing the plates into their final position once the arms are in place. Making the right Pauldron will be exactly the same as the left so the next instalment will probably be getting to grips with Frederick’s scratch build battle shield (then I can sort out his final left arm positioning).
Until then, happy modelling to you All!
Robin.
7 Pages <1234>»
This page was generated in 0.786 seconds.
