Joined: 08/02/2015 Posts: 274 Points: 812 Location: Malmesbury
hi all, I am going to start building my deagostini rc spitfire this week end and was wondering which type of glue to use? I have gorilla glue and aliphatic rapid glue, or should I be looking at getting something else? Any suggestions would be greatly appreciated Best regards Shaun Building-RC spitfire Build- titanic,Skyrider drone, solar system, T72 tank
Hi Shauncnh, As l am not familiar with this build can you tell us what type of material it will be made of. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
tf64 wrote:Hi Shauncnh, As l am not familiar with this build can you tell us what type of material it will be made of. Regards Trev. Hi Trev, thanks for your reply  . It is a plywood frame with wooden stingers and a balsa wood skin which is then wrapped with a heat shrink plastic. The frame has to be strong as I plan on flying it and it is powered buy a nitro engine. Best regards Shaun Building-RC spitfire Build- titanic,Skyrider drone, solar system, T72 tank
Original Gorilla is much heavier than PVA.
On a RC aircraft your looking to keep the overall weight down. I used Aliphatic for the wooden structure. Also, the orginal Gorilla glue is water activated, the last thing you want is your airframe water soaked!
Don't attempt to fly your Spit unless you have previous model aircraft flight experience. Get a high wing trainer and join a club. But even after a Trainer, a nitro Spitfire is a 3rd or 4th model to aspire to because of its fast agile flight and low wing.
The existing elevator and aileron pushrods are a bit on the soft side, so its a good idea to upgrade these and also upgrade the aileron links. You can use birch dowel or bowden cable, and keep their route as straight as possible.
Finally its a good idea to join the BMFA which also provide 3rd party insurance.
Hi Mr T, Thanks for the advice  , I'll stick to the Aliphatic glue I've been using on to build my Lancaster with. I have been looking at getting a trainer plane to practice with. Hopefully going to start the build later today or tomorrow, just got to finish a few jobs off at work first. Regards Shaun Building-RC spitfire Build- titanic,Skyrider drone, solar system, T72 tank
