 Thanks both for looking in and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Impressive work Andy and looking fab....pity about the screwdriver mishap, sound advice given though...... Regards Alan
Great work Andy. Loving seeing this one grow. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
All looking very nice. Happy Modelling
 Thanks everyone for looking in and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 26/11/2015 Posts: 238 Points: 723 Location: Seattle, Washington
Absolutely awesome job, Andy! Looks amazing! Keep it up!  Completed Building Walter Wolf's Lamborghini Countach LP 500S, Harley Davidson Fat Boy, Suzuki GSX 1300R Hayabusa, Honda CB750. Planning to Build Easy Rider Bike, Valentino Rossi's Yamaha YZR-M1
 Hi Dave thanks for looking in and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 19/05/2015 Posts: 1,419 Points: 4,272 Location: Darmstadt, Germany
Looks awesome. They've done a really beautiful job with the paint.
 Hi Greyhawk Sorry I missed your post and thanks for looking in and your comments. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Pack 18 is here, basicley a repeat of last month but we do the other rear wing all went together without any problems. The last part this month is the front wind shield and rear view mirror assembly all I did here was to check it had no damage and repacked it as I will fit it later when the upper body shell is here. More soon. Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 11/02/2015 Posts: 126 Points: 390 Location: Gloucester
Very nice, i just received pack 16, unfortunately the contents was pack 6, Phone call on Monday and a 3 or 4 week delay for the correct pack, but this build is worth it!!
Jon
Looking good Andy, mine also arrived today but not a chance to assemble it yet  damn these 12 hour shifts. It's certainly going to be a heavy old thing when it's finished
 Hi Jon and Dave Jon sorry about your wrong parts but agree totally its an outstanding build of a classic car. Dave I used to do 12 hour shifts too so know how it feels, I think I may need to beef up a table to hold this beast when its finished and thanks both of you for looking in. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Pack 19 arrived  ,so on with the build added the windscreen, periscope and inner roof the the roof and then the rear spacer. Added the LED's to the left and right rear wings [ I put the longest wire on the right side as its furthest away from the circuit board] then the strut was also added to the rear boot. Lastly the two rear wings were joined up with the rear light cluster. Be carefull with the joined rear parts as only two screws hold it together right now. Could,nt resist adding the rear to the chassis as you can see from the last pic. More soon Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good Andy, I wonder if you drooled as much as I did
Looks great. I need to get round to Mine!
Jon
Looking awesome, Andy! Almost there! Completed Building Walter Wolf's Lamborghini Countach LP 500S, Harley Davidson Fat Boy, Suzuki GSX 1300R Hayabusa, Honda CB750. Planning to Build Easy Rider Bike, Valentino Rossi's Yamaha YZR-M1
 Hi All Pack 20  has arrived  . The first part of the pack is a heavy chassis with a small brass plate and screws. The plate records that the car was made for Walter Wolf. This is stuck to the chassis as specified. The second item is the boot liner and lock simply remove the tape cover ind stick in position. The third part is our first headlight unit I tested both lights to make sure they worked then added the two lenses to the unit. More soon. Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice work Andy, just done my parts and also tested both bulbs Al
Guest (28)
