Rear and Side Gallery glazing Options
Stephen01
#1 Posted : 21 March 2016 16:35:11
Rank: Beginner Level 1
Hello All,
I wonder if i might please ask for some advice?I am about to glue the rear gallery in place followed shortly after by the side galleries and I am wondering about the correct time to fit the yellow glazing supplied for the windows. Should I glue it in place now or wait until later?
Many thanks
Stephen
#2 Posted : 21 March 2016 17:13:19
Hi Stephen, you need to construct the gallery first. The yellow glazing will be applied to the outside and window framing build around it. This shows you when and how it is put together...
http://forum.model-space...aspx?g=posts&t=3088
Hope this helps.
GilShapley
#3 Posted : 21 March 2016 17:41:26
Hi Stephen
The fitting of the gallery windows and frames is covered in issue 83
Current Build:-
Stephen01
#4 Posted : 22 March 2016 23:35:10
Thank you both very much, you saved me from a huge mistake! I was getting ready to glue the yellow glazring inside the rear and side galleries.
Thanks again
Stephen
#5 Posted : 22 March 2016 23:42:10
Hi Stephen, pleased we were able to help you. Just shows the value of asking questions on this forum and doing build diaries, it helps us to ensure many mistakes are avoided.....Cool Cool .. Hope the rest of your build is trouble free....
This page was generated in 0.039 seconds.
