ok i gotta ask Options
secretreeve
#1 Posted : 13 October 2010 01:37:48
on simple question.
what the heck is a windlass for?
willz
#2 Posted : 13 October 2010 02:01:45
Active Service Medal: 500 post active service MedalTurquoise Medal: Turquoise Medal for model making know-how contributionOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of Honour
it carries the anchor underneath the launch
willz attached the following image(s):
CMB
#3 Posted : 13 October 2010 02:14:46
I googled and came up with this:-
The windlass is a means of converting rotary motion to linear motion, usually with some mechanical advantage.
Essentially a class 1 lever, the effort is applied to the handle of the crank, the fulcrum is the centre of the drum, and the load is applied to the rope. The mechanical advantage is approximately the length of the crank divided by the diameter of the drum.
Since starting this build I learn something new almost daily.
Happy building
CMB[BigGrin
Atholm
#4 Posted : 13 October 2010 09:24:42
To me a windlass is a nautical term for a simple rope and block lifting devise (Simple crane)
#5 Posted : 13 October 2010 09:48:22
to me, the word windlass is mean't to mean windless,it's use is to move the ship when there is no wind,drop the anchor out at sea,and wind like crazy to move the ship.
Kirill
#6 Posted : 14 October 2010 07:55:15
Rank: Beginner Level 3
A windlass is a smaller version of a capstan, primarily used in smaller vessels.
budgie
#7 Posted : 14 October 2010 10:28:05
quote period pieces #36 "a horizontal winch for anchor work similar in use to a capstan"
capstan~ a vertically mounted rotating device for raising the anchor
This page was generated in 1.972 seconds.
