problem with my second deck need help please Options
comtechy
#1 Posted : 13 October 2010 12:24:20
was sitting down today doing the hms has i was putting the beams in i noticed this problem i got i tried to queeze it but i heard a crack can be fixed but need some help how to sort this problem out please
willie
#2 Posted : 13 October 2010 12:39:47
the crack was a rib you will need to ease the beam on the ribs i done the same find the tight rib that cracked and fix may be with a stinfer , keep the beam right angle to deck i filed down where the beam tuched the tight ribs
This page was generated in 0.094 seconds.
