Clutch Bell Housing Options
GilShapley
#1 Posted : 30 March 2016 14:44:06
Just started packs 74-76 the clutch housing
Once stage 76 has been completed and the small screw and washer used to attach the bell housing should there be any movement along the pilot shaft. (The clutch houseing spins freely on the bearing) I have tightened the screw as far as i can but there is movement along the shaft of about 1mm
Confused Confused Confused Confused Confused Confused Confused
Current Build:-
#2 Posted : 30 March 2016 15:10:17
Its common for there to be slight movement. The most important thing is that you have greased the pilot shaft and needle rollerbearing.
GilShapley
#3 Posted : 30 March 2016 15:20:07
Many thanks Mr T
I have greased the bearing and shaft as suggested so now onto the next step
Current Build:-
This page was generated in 0.991 seconds.
