21 Pages «<89101112>»
#181 Posted : 30 March 2016 12:20:25
Some beautiful impressive work going on there Andy. Well done.Drool
#182 Posted : 30 March 2016 18:00:56
BigGrin Hi Hans Thanks for your comments and looking inCool
#183 Posted : 30 March 2016 18:15:02
she look`s brilliant Andy well done mateCool regards Phil
#184 Posted : 31 March 2016 07:07:45
Hi Andy, BigGrin
Very impressed so far and with the scratch building it can only get better. Cool
Looking forward to the future updates.
#185 Posted : 31 March 2016 09:41:03
Looking good Andy, nice work. Cool ThumpUp
#186 Posted : 31 March 2016 11:23:40
Hi Andy.
Deck work is coming together nicely.
Look forward to your next post. Ian Cool BigGrin
#187 Posted : 31 March 2016 16:34:04
BigGrin Thanks everyone for looking in and your commentsCool
#188 Posted : 03 April 2016 18:23:32
Slow but steady progress on the skullcap facets, I made a small mistake which involved the removal and replacement of some facets but back on the right track now although some filler will be needed to correct some small blemishes. Still a good deal to be done here. More soon .
#189 Posted : 03 April 2016 19:10:19
Hi Andy,
Good progress, I can see more to shape you are building, I know that it's not easy cutting facets and make them sit to each other, so from what I can see there spot on.
Trev
#190 Posted : 03 April 2016 21:22:44
BigGrin Hi Trev
#191 Posted : 03 April 2016 23:08:45
Gets better and better Andy, wonderful work.....Cool Cool
#192 Posted : 04 April 2016 08:22:51
Very well done on that part of your build - angles and the like are very difficult.
Its a very well made part of your build.
#193 Posted : 04 April 2016 11:27:11
Hi Andy.
Coming along nicely.
Look forward to your next instalment.
Ian Cool BigGrin
#194 Posted : 04 April 2016 19:43:25
#195 Posted : 10 April 2016 17:25:43
The basic shape of the skullcap is more or less finished cant quite seem to get the angles on the upper bridge to match but I will go back to it at some point just had enough of it for now. The final facets were attached then P38 filler was used and sanded back before that final row of plates were added the curved side plates were added and again filler was used to tidy everything up. the area's around the running lights have been tidyied up and then shaped to match the hull. More soon.
#196 Posted : 10 April 2016 18:32:18
That is looking good, and I am sure you will iron out the any problems with the bridge.ThumpUp BigGrin
#197 Posted : 10 April 2016 21:40:14
BigGrin Hi Nem thanks for looking in and your commentsCool
#198 Posted : 10 April 2016 22:41:06
Hi Andy,
Just had a look, very good panel work should sand up a treat.
Trev
#199 Posted : 11 April 2016 11:32:02
Hi Andy.
Looking very nice, keep the pictures s coming. IanCool BigGrin
#200 Posted : 11 April 2016 17:03:06
BigGrin Thanks for looking in guys and your commentsCool
Guest (11)
This page was generated in 0.248 seconds.
