rolo Options
rolo
#1 Posted : 02 April 2016 15:20:10
Rank: Newbie
Having problems charging my battery.
When plugged in the charge LED + cell 1 LED or Cell 2 LED (voltage difference among cells is to large >300mv or wrong connection) starts flashing. Is there any way to correct this?
#2 Posted : 02 April 2016 16:25:31
Have you followed the manufacturer site instructions?
http://manuals.hobbico.c...dtx/dtxp4620-manual.pdf
rolo
#3 Posted : 02 April 2016 18:58:07
Rank: Newbie
Hello Tomick Yes read and followed the instructions that came with it.I did plug the battery into my drone before i tried to charge it to do the GPS test and the motor test . Motor test went well all going in the right direction. About 2 minutes into test motors stopped turning and a constant high pitched siren started which is when i decided to charge the battery.
rmdo92
#4 Posted : 03 April 2016 09:44:46
Rank: Beginner Level 3
I see the same problem, I have reread it a few times
I can not see the Battery, on the website of FlightPower, for the FP25 5000mAh they only have it going up to 4000Ah
This page was generated in 0.094 seconds.
