Having problems charging my battery.
When plugged in the charge LED + cell 1 LED or Cell 2 LED (voltage difference among cells is to large >300mv or wrong connection) starts flashing. Is there any way to correct this?
Have you followed the manufacturer site instructions? http://manuals.hobbico.c...dtx/dtxp4620-manual.pdf
Hello Tomick Yes read and followed the instructions that came with it.I did plug the battery into my drone before i tried to charge it to do the GPS test and the motor test . Motor test went well all going in the right direction. About 2 minutes into test motors stopped turning and a constant high pitched siren started which is when i decided to charge the battery.
I see the same problem, I have reread it a few times
I can not see the Battery, on the website of FlightPower, for the FP25 5000mAh they only have it going up to 4000Ah
