The shell Options
rmdo92
#1 Posted : 05 April 2016 19:58:12
Rank: Beginner Level 3
I am should I have just missed a bit some where.
from want I can tell once I stick all the bits of the shell that goes over the up, there is no way of getting it on or off.
Want have I missed?
I would normal look at he youTube videos, but they are not up yet for part 12.
Roger
michu
#2 Posted : 05 April 2016 22:46:00
The front part needs to be removed while you are installing the shell, then you should add it again after sliding the shell on from the back.
Happy building :-)
kenjara
#3 Posted : 06 April 2016 00:03:47
Anyone know a good easy way to get the tape off cleanly each time. No idea why the instructions said to attach the front part only to remove it and make a mess in the last stage. Seems a bit of a design flaw they you need to untape it to remove the shell each time.
#4 Posted : 06 April 2016 07:52:30
You need to use a solvent cleaner to remove the tape residue, but first test on an unseen area as some solvent cleaners may attack the PVC plastic.
You could consider using ultra thin velcro tape instead of double-sided.
kenjara
#5 Posted : 06 April 2016 08:39:30
Tom you are a genius, I have loads of those velcro strips laying around.
I will clean off the residue and give it a go.
Thanks,
Shane
#6 Posted : 06 April 2016 09:18:38
One source here for ultra thin if needed
https://www.etsy.com/uk/...ZyrvJ-csCFUKeGwodHqYFIA
kenjara
#7 Posted : 07 April 2016 21:26:02
Well I did what you suggested and it works well. I actually had to remove some as it was sticking too well. :P
Now I have balance the props I am ready to go. Battery is taking forever to balance though.
#8 Posted : 08 April 2016 08:11:00
Initial charge is approx 8 to 10 hours
kenjara
#9 Posted : 08 April 2016 08:32:17
Thanks Tom, that's good then.
I have never had a LIPO battery that large before so was not sure what to expect.
#10 Posted : 08 April 2016 10:20:16
Never leave it unattended during charging and carefully follow all of the LiPo info provided in the magazine., not to be alarmist but LiPo's can burst into flames or explode if handled incorrectly Blink
michu
#11 Posted : 08 April 2016 10:45:06
Especially if punctured or shorted - and both can happen if not being careful when storing or transporting.
Happy building :-)
kenjara
#12 Posted : 08 April 2016 12:15:10
Yeah, although in a few years of using LIPO's I have never had any issues they still make me paranoid.
I already had an additional LIPO sack ready just for the battery and charge it in the conservatory away from everything.
I routinely check to see if its got hot or expanded at all while its charging.
This page was generated in 0.113 seconds.
