Electrics not working on my suzuki - now sorted! Options
#1 Posted : 06 April 2016 21:03:08
Hi wonder if any one can help.I have no sound whatsoever on my bike, when turn the power on the headlights taillight and in instrument panel all flicker.when use indicaters this kills all lights though they seem to be working.have checked all connections on bike with test board all fine.and the 3 switches on control panel all pass on test board to.so it either the potentiometer gone or control panel or control board.bit at a loss to see what else can check.thanks mick. Confused
#2 Posted : 06 April 2016 22:12:08
Hi Mick
You probably have them lined up already but best to check.
Is the infa red sender and receiver on the bottom of the engine and base in line with each other.
#3 Posted : 06 April 2016 22:26:56
Hi Andy yes made sure of that.it be something daft, but it finding it the problem, oh well ill get me brother to look, he can check in lot more detail than I can.
bugsec
#4 Posted : 07 April 2016 00:19:37
I've got a similar issue. When I turn on the power I get no lights, indicators and full beam don't work. I do have engine sound and horn. Brake light works. Ignition key on handle bars works (brake light stops working when removed).
IR transmitter appears ok using the 'camera' test.
Next step is to test the switches on the control panel but I don't think that's the issue as the parts in the base (engine and horn sounds) work and parts on the bike (brake light) work.
Seems to be a IR transmission issue between the base and the bike just not sure how I can check that.
Graham
#5 Posted : 07 April 2016 07:22:43
Check that the main circuit board has not been cracked during placement as we've had a couple that have been reported as throwing up such problems as a result. Then do an individual plug by plug check for what works okay individually.
#6 Posted : 07 April 2016 13:08:44
Hi thanks for the advice MrT. I have tried each light ie taillight.headlight indicaters all individually as suggested. And get the same flickering on all of them.I can't see any cracks or damage to control board even under magnification, the ir seems okay as have to move the control box few inches away before loose contact with bike.still have no sound but this not go through bike.it should work control box alone.so wondering if it's the control box at fault?.cheers mick. Confused
#7 Posted : 04 June 2016 10:47:38
Hi just an update on electrics. It was the control board on the bike at fault. I got replacement and all is working fine now. Just one more pack and be complete. Cheers mick. (Big grin)
#8 Posted : 04 June 2016 10:54:56
Glad you got it sorted Mick, I am awaiting the last pack aswell!
#9 Posted : 04 June 2016 11:20:04
Good stuff!
#10 Posted : 04 June 2016 18:39:14
Great that you got it sorted Mick
This page was generated in 0.308 seconds.
