changing problem, want have I done wrong????? Options
rmdo92
#1 Posted : 09 April 2016 18:57:51
Rank: Beginner Level 3
OK, all I can get out of the changer is, to get led 2 flash?
I have left it for hours and still, it only flashes led 2
Roger
kenjara
#2 Posted : 09 April 2016 20:08:42
Do you mean the cell 2 led? What color is the main led?
Have you pluged both the deans connector and the balance connector into the charger?
rmdo92
#3 Posted : 09 April 2016 20:13:33
Yes and yes
kenjara
#4 Posted : 09 April 2016 20:29:50
How long has it been. If cell 1 and 3 are constant read and 2 is flashing it means it's balancing. Are all other LEDs off?
rmdo92
#5 Posted : 09 April 2016 20:42:04
I get all red when plug in mains in to the changer
then it goes to green flashing
plug in +/- cable and still have green flashing
Then plug in the 4 way cable into the middle socket on the side and it goes to just the cell 2 led flashing, and all other leds out.
unplug it and the changer goes to the green flash.
just plugging in the 4 way cable it goes to just cell 2 led flashing only
kenjara
#6 Posted : 10 April 2016 19:32:04
Hi
I just thought it might help if I take note of what happens to my charger when I plug it in.
If I plug the white balance connector in first then led 2 flashes just as you describe. As soon as I plug the deans connector in the leds show that it is charging (all leds red).
Perhaps it is not detecting the +/- connection?
rmdo92
#7 Posted : 11 April 2016 20:26:31
I 99% sure it is the right way around
kenjara
#8 Posted : 11 April 2016 20:54:51
All looks good to me.
#9 Posted : 12 April 2016 11:17:14
How does it compare with the error codes
http://manuals.hobbico.c...dtx/dtxp4620-manual.pdf
kenjara
#10 Posted : 12 April 2016 11:50:32
Looking at the error code for cell 2 flashing it says wrong connection. Not the most specific error.
rmdo92
#11 Posted : 13 April 2016 06:56:20
I would say it was error 2, but the change led is not on.
if it was error 2 want can I do about it?
#12 Posted : 13 April 2016 07:13:00
Both items are supplied together, ask for a replacement
This page was generated in 0.112 seconds.
