Stage 71 Help Options
bugsec
#1 Posted : 10 April 2016 18:45:44
I have a problem with the electrics. When I turn on the power I get no lights, indicators and full beam don't work. I do have engine sound and horn. Brake light works. Ignition key on handle bars works (brake light stops working when removed).
IR transmitter appears ok using the 'camera' test.
Switches in the base control box have been tested and are all working.
I've re-tested all LEDs and all are working
Seems to be a IR transmission issue between the base and the bike just not sure how I can check that. I think I need some way to test that the control board on the bike is receiving IR transmissions.
Any suggestions on how to resolve greatly appreciated.
Graham
#2 Posted : 10 April 2016 18:56:35
I would say that it's the main board at fault and suggest replacement as there is no way to check it.
bugsec
#3 Posted : 10 April 2016 19:08:24
Hi Tom,
Thanks for the quick response.
I take it you mean the main board on the bike?
I'll speak to C/S in the morning.
Graham
#4 Posted : 10 April 2016 20:50:50
Yes the bike
bugsec
#5 Posted : 16 May 2016 10:07:14
After a couple false starts should get the replacement part this week.
Graham
This page was generated in 0.091 seconds.
