Space between inner and outer hallway walls for lighting the Falcon Question Options
LrdSatyr8
#1 Posted : 06 April 2016 19:28:09
Ok... I've been thinking of lighting my hallways and putting the sconces on the wall, however, I've been wondering just how much space is available between the inner and outer walls. The area I'm most concerned about is the corridor leading to the cockpit. From the looks of it there doesn't appear to be much room for electronics between the outer hull and cockpit corridor at all. Which means I will have to change my entire way of planning out the electronics for it.
Now if there's enough space, using an LED with bent legs should work, if not, I may end up having to use strip LEDs or even sheet lighting. The space between would mean the difference between all these options! Anyone have an answer that could help?
LrdSatyr8
#2 Posted : 11 April 2016 16:01:16
Not even a guess here?
#3 Posted : 11 April 2016 17:58:23
I have seen some Facebook build diaries where they are using the LEd strips for the hallway lighting.I would imagine they would not be a problem since they are so low profile and easier to deal with than EL strips.
LeviathanPrime
#4 Posted : 11 April 2016 21:55:47
Would it not be possible to get any info on the final product? Surely someone involved in the design could answer this or provide some details on the finished build.
#5 Posted : 11 April 2016 22:22:41
You would need to post this on the buildthemillenniumfalcon website to reach the publishers.
This page was generated in 0.400 seconds.
