TheFlyingCouch wrote:I wish the Lambo came as a complete kit. The Toyota is a cool kit.
Jon The Countach will be available as a full kit once the Subscription has run its course
Joined: 11/02/2015 Posts: 126 Points: 390 Location: Gloucester
My 2000GT case arrived today!! Jon TheFlyingCouch attached the following image(s):
 That looks the bizz Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Vice-Master       Groups: Registered
Joined: 07/01/2015 Posts: 856 Points: 2,479 Location: Sevenoaks, UK
Got one too! :) I need a bigger house... Any images I post on my personal builds are free to be used and shared under Creative Commons Attribution license, which means you can do what you want with them, on the condition you mention I'm the author.
Happy building :-) http://www.model-space.com/gb/
Yeap, well i am having a man cave built soon, for all my kits and collectables!
Jon
Stages 11 to 21 now completed, no problems but be careful with the distributer leads. had to use a little glue to secure them in place. Regards Jon TheFlyingCouch attached the following image(s):
Nice job. Did you glue in the battery leads too? There are replacement cables provided in Stage 59 that are pointed to the left instead of to the right, which makes them fit better when installed into the car body. Any images I post on my personal builds are free to be used and shared under Creative Commons Attribution license, which means you can do what you want with them, on the condition you mention I'm the author.
No i have not glued the battery leads, thanks for the advice!!
Regards Jon
Stages 22 to 30 now completed, be carful with the tiny dashboard switches, use a decent pair of tweezers!! Jon TheFlyingCouch attached the following image(s):
 Looking very nice Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Wow, looking good Jon, awesome build
Great work :) How do you find the gear shift lever? In my opinion that's the most fiddly part of the whole build; I wasn't able to assemble it without CA glue. Any images I post on my personal builds are free to be used and shared under Creative Commons Attribution license, which means you can do what you want with them, on the condition you mention I'm the author.
Hi Jon, Looking good so far, thanks for pointing out the odd bits that need extra attention . Will come in handy when I get round to building mine. Keep up the good work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Lovely progress Jon, looks amazing Steve
Thanks for the comments, the Gear lever assembly took a little play to get it right. What i found best was to insert the base first into the body of the car, lining up the small projection, then i added the gaiter and finally the lever.
Jon
 great looking Build Regards Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Great progress Jon, looks fab.... Regards Alan
Great to see your making good progress with your Toyota 🚘.😎 The engine looks very detailed. Are you planning a straight ootb build of are you going to add few little tweeks. Regards Chris 👍 On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
No Tweaks just a straight build!!
Regards Jon
Joined: 28/05/2013 Posts: 34 Points: 105 Location: Scarborough
Looking good. Can't wait to start mine. Hopefully it is arriving this Thursday.
Guest (22)
