Joined: 11/04/2016 Posts: 5 Points: 15 Location: JAPAN
I hope someone can help with a problem with my drone. I received my final kit last Sunday and now in the process of linking the rc control and the drone. However when I plug the battery to the drone there is a constant slow beeping, blue arm light is constantly on, red tail arm is constantly flashing slowly, and tail led is rotating flashing pattern of blue,red,and green. I followed the instructions but to no avail I cannot get the drone to go into calibration. The battery is fully charged. Please help. Thank you!
Joined: 05/04/2013 Posts: 540 Points: 1,630 Location: England
It sounds like you have not bound the drone to the transmitter yet. If that's the case there is a little button on the drone receiver that you need to press while the transmitter is on. They should then bind and the beeping should stop. Finished 3D Printer, RB7, Hummer, Skyrider drone & Combat tank collection http://www.model-space.com/gb/
The pre-flight video show's how to link the Receiver with the Transmitter
http://forum.model-space...spx?g=posts&t=18805
Thanks for the reply! Unfortunately, the link on the post is to a pdf file for the manual for battery charger. Also I tried linking the transmitter and receiver. I inserted a screwdriver into the little hole in the receiver and pressed for 1 second. It flashed twice and the LED became constant red indicating it is linked. But it still is not working. When I plug in the battery to the drone is it supposed to make beeping noise from the 4 arms? When I turn on the main switch it still the same status when I first posted in the forum. Front arm blue light is on, rear arm light is flashing red, beeping coming from arms, tail LED is rotating blue, red, green. I wonder if I have a defective circuit board or receiver?
Possibly so, you'll need to contact c/s in Japan to obtain this
Thanks Mr T. I have one last question to ask before calling c/s. I can hear the beeping noise coming from 3 of the 4 motors. The rear right motor is not beeping. I switched the motor cable to the rear left esc and vice versa. When I connect the battery the rear right motor still does not beep. Could it possible that all the LED flashing light is an indicator for a motor malfunction? I f so I will contact c/s in Japan to get replacement motor.
Have you seen this info.. http://forum.model-space...spx?g=posts&t=17956
Also the compressive set-up info here... http://forum.model-space...spx?g=posts&t=17972
In particular have a look at the motors.
Thanks Mr T. Yes, before posting on the forum I did look at the two links which you provided. Very helpful. Thank you! My wife who is japanese looked on deagostini japan forum and another person like me has the same problem. I will contact c/s japan this week. Thanks for all your help!
Just to let you know, I troubled shooted the problem done to a faulty motor assembly. The copper coil was severed in two locations causing a short. Calling customer service to get replacement. The drone with the faulty motor disconnected, the drone LED and beeping became normal like how the instructions were written and I was able to link and confirm three of the four motors work. Thank you all for your help!
That's great and well done
