Pathway for wing lights Options
m0325
#1 Posted : 15 April 2016 18:01:42
What is the pathway for the two light cables from the wing tip to the battery box
#2 Posted : 15 April 2016 23:04:12
Via the most direct route, much the same as the Fus and Tail lights
#3 Posted : 16 April 2016 13:28:21
Hi m0325,
As Tom said the most direct route, so that means all the wires are arranged in the underside of the plane and a hatch which is supplied will keep them all enclosed, this will be under the cockpit, then just screw the wing back in place.
Trev.
This page was generated in 0.091 seconds.
