I have a collection of Die cast planes and helicopters, I don't know if any other forum Members collect these. The model is made by Fighting Forces. Apache AH64-A 1st Air Cavalry Division Kuwait 1991. 1:48 scale. Real size information. Crew 2, Rotor diameter 14,630mm, Length 17,576.8mm, Height 429,26mm, Armament 1 x 30mm Chain gun cannon, 8 x Hellfire anti Tank missiles ( both sides ), 2 x 2.75 inch Rocket pods ( both sides ), 2 x AIM-9 Sidewinder Missiles ( Both sides ) weight 10,700 pounds, maximum weight 21,000 pounds, Motor 2 x 1.73 SHP General Electric T700-GE 701 Engines. Maximum flight speed 284 KMH, Maximum rate of climb 881 mpm, Vertical rate of climb 651 mpm, Range 400KM Internal fuel tank, 1900km with internal and external fuel tanks. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Now you need the Deag one to go with it Ian!!
Nice looking model Ian, will be interested in seething other pieces in your collection.... Regards Alan
Awesome!! I too am interested in seeing what others you have
Hi Guys, Thank you for looking in and your comments. I will post some more of my collection for you, I will also post a few closer pictures of the Apache, so you can see a bit more of her details. Regards Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
ian smith wrote:Hi Guys, Thank you for looking in and your comments. I will post some more of my collection for you, I will also post a few closer pictures of the Apache, so you can see a bit more of her details. Regards Ian. Hi Ian  . I would  to see more of your collection. Best regards. Mark
Hi mark. Thanks for looking in. And your coments Regards Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi All. A few more Apache Pictures. ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Very detailed looking piece Ian, lovely to see..... Regards Alan
Hi Alan. Thank you for looking in and your comments, will post some more of my collection soon. Regards Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
