Hi everyone, I'm considering subscribing to the Fi Vodafone car but need something clearing up for me. The subscription is for 21 months but there are 12 packs delivered? Could someone explain how this works please, many thanks.
I have just had a good read through the write up and from what I can see it is a 21 month subscription, there is no 12 month option on this build. Hope that helps.
That's what's confusing, I know there isn't a 12 month subscription but there are 12 packs sent with several issues in each pack. If you click on "the build" tab you'll see what I mean. Col attached the following image(s):
Joined: 08/02/2015 Posts: 274 Points: 812 Location: Malmesbury
Hi Col, I think looking at it you make 21 monthly payments but only receive a pack every 7 weeks as there are 7 stages in each pack and their are 85 stages all together. Hope this helps. Regards Shaun Building-RC spitfire Build- titanic,Skyrider drone, solar system, T72 tank
 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,496 Points: 4,400 Location: Essex
There are 2 complete kits on ebay at the moment, both are under £500. I'd be tempted to buy 1 of them. You get it all straight away then. That's what I did. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
If I could afford to buy the complete set I would, but the subscription is the only real option. And thanks Shaun.
Web page has been corrected - It's 20 Packs/20 Months and start for just £9.99 - You will receive your first shipment for £9.99 and your next 19 monthly shipments at £40 each.
http://www.model-space.c...-the-senna-mclaren.html
