Problem with Binder Options
z8000783
#1 Posted : 17 October 2010 19:54:03
Groups: Unapproved
I have just received my second binder and it's slightly different compared with the first so I thought I would check with you guys before I ring CS tomorrow.
On the first one I received there was a small cover, top and bottom, that closed and locked into place to stop the plastic pins from falling out, as they indeed did if the cover was open while I was putting in the latest issues.
My new binder does not seem to have these clips. Is this a fault with mine or a manufacturing or even a redesign problem?
John
secretreeve
#2 Posted : 17 October 2010 19:58:46
that definatly sounds like a majour fault.
although you could superglue th bottom pins in place and leae the top ones as they are incase you want to remove one of the issues.
z8000783
#3 Posted : 17 October 2010 20:00:21
Groups: Unapproved
Do have have your second binder yet?
John
Boaz
#4 Posted : 17 October 2010 20:12:55
I had the same thoughtHuh
But I did notice when the binder goes in it tends to force the end of the clip into a recess.
Bob
z8000783
#5 Posted : 17 October 2010 20:14:24
Groups: Unapproved
So your second one does not have the clip either as the first one did?
John
secretreeve
#6 Posted : 17 October 2010 20:48:42
no i opted out of the extra binders.
i was just adding what came to mind in hopes it would help.
z8000783
#7 Posted : 17 October 2010 20:49:23
Groups: Unapproved
Thanks
axle396
#8 Posted : 17 October 2010 21:03:11
Mine was different too. Different method of holding the clips in place. Seems to do the job though.
Jimmy L.
Revell USS Kearsarge
Titanic Lifeboat
z8000783
#9 Posted : 17 October 2010 21:05:39
Groups: Unapproved
I am in the UK at present and my first binder in is Greece. How is it different? It looks the same to me but without the clip.
John
axle396
#10 Posted : 18 October 2010 10:58:20
John
One(the first) has a little hinged flap that snaps closed to hold the little pins in place and the other has a recess that you have to push the pins past to secure them. Both work fine.
Jimmy L.
Titanic Lifeboat
z8000783
#11 Posted : 18 October 2010 11:01:50
Groups: Unapproved
axle396 wrote:
John
Thanks Jimmy, I shall have a look before hitting the phones.
John
This page was generated in 0.802 seconds.
