Loose front wheel bearings Options
Steve279021
#1 Posted : 20 April 2016 17:29:15
I have just fitted the front bearings and wheels onto the axles and the bearings on 1 of the wheels are quite a loose fit in the wheel. So when the wheel is bolted onto the axle it is quite wobbly. Has anyone else come across this?
Dodge charger build complete
Senna lotus 97t complete
#2 Posted : 20 April 2016 17:53:34
As you paying catch up, its always a good idea to first check the previous discussions
http://forum.model-space...aspx?g=posts&t=7700
The upshot is (and after many have now completd and run their RB7), there has not been a problem as a result of a slight sloppy fit of the wheel bearings.
Steve279021
#3 Posted : 20 April 2016 18:17:11
Ok. Thanks Mr T. I have read it now and I might try the ptfe route and see how that goes.
#4 Posted : 20 April 2016 20:15:51
PTFE tape often works, but ensure that it's even otherwise it will create wheel bounce.
Aquanin
#5 Posted : 20 April 2016 20:31:39
I ave found the loose bearings not to be a problem at all when running the car. Everything works great.
This page was generated in 0.358 seconds.
