 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,705 Points: 17,267 Location: ipswich
I started on this one quite a long time ago and shelved it as I was well into my DBR1 and planning the Cunningham E Type - both on the forum somewhere... The shell was cast quite a while ago and was gathering dust so it's been dusted off and cleaned up. The panels are now cut out ready for all the opening bits and the body is in grey primer after a ton of wet sanding. A wood internal firewall and floor are screwed in for strength, but also for easy removal when I start the interior etc. The model is going to be number 22 - Nick Mason's GTO. Roy.
Amazing Roy, you should make this a 1/8 kit!! I would buy one! I have MFH 1/12 GTO engine./It is metal and has working pistons.You should build a 1/8 engine with working pistons too.
Joined: 05/05/2014 Posts: 230 Points: 657 Location: Northeast USA
+1 on an 8th scale 250GTO kit, something DeAg should consider producing.
Thanks you guys. The model will have a full engine etc but I'll give the pistons a miss. I might build a stand-alone engine too to go with the car, as I did with my Aston DBR1. The car now has 3 base coats of red primer, umpteen wet sandings and a fist layer of Rosso Cina red. Lots more sanding, more paint, and polishing... Roy.
Outstanding work After seeing how your other scratch built cars have turned out I can already see this is going to be quite something when finished  eagerly awaiting the next part
Lovely, something about a red Ferrari that stirs the inner child, outer one too!!  Cant wait to see the finished paint, gonna need sunny's!!
OK... It's changed. Now the 1964 Ecurie Francorchamps winner. A good few alterations needed, not least of which, 2 gills instead of 3, open front vents, and silver. Interior and chassis started. Also, now got some of the 3D printed engine parts... Roy.
Great work Roy. Your doing a nice job on them.3d engine parts. Will make a massive difference to the build. Well done mate Chris 👍😎 On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Sorry for the slow updates... The main engine is together and I've started adding the details. Tons yet to go before I can fit the engine to the chassis. Roy.
Superb work on the engine, it will look fantastic once in the car!
Looks great Roy.I am building a 1/12 GTO engine.
This is a stunning build that I'm really enjoying following. Awesome work Roy
Fantastic work. Great 3D printed parts.
 Rank: Vice-Master       Groups: Registered
Joined: 07/01/2015 Posts: 856 Points: 2,479 Location: Sevenoaks, UK
Amazing work! Any images I post on my personal builds are free to be used and shared under Creative Commons Attribution license, which means you can do what you want with them, on the condition you mention I'm the author.
Happy building :-) http://www.model-space.com/gb/
