2 Pages 12>
Panzerkamphwagen V Panther Options
#1 Posted : 25 April 2016 12:08:49
Hi all back in 1981 I had a very bad bike accident and was in hospital for 8 months and after I came home I couldn't work for another 7 months as I needed a lot of physio to get me walking again. To stop me going crazy the wife got me this model so it has a lot of memories Blink
This kit made by Tamiya is going to be a straight out of the box build and when I opened the box it looks like they haven't retooled it from when I first got one back in the 80s Laugh
Hopefully will get this going in the next few days Cool
Cheers for looking rgd Martyn
#2 Posted : 25 April 2016 18:13:29
I have couple in my stash, an old one and a new one. I just looked at both and I cant see a difference!Blink LOL BigGrin Good kit though, I do like the Panther.BigGrin
#3 Posted : 25 April 2016 18:39:27
Love Hi Nem I love the Panther a very nice looking tank . My first one I built I did as a dio I had it in the Eastern front and put lots snow and ice round it Cool Not sure how I am going to finish this one yet but definitely going to do a dio Cool
Thanks for following rgd Martyn
#4 Posted : 25 April 2016 19:26:46
BigGrin The Tank that all modern tanks are based upon my top tank too, Built the Dragon version a few years back and will look forward to your build diaryCool
#5 Posted : 12 May 2016 11:59:47
Hi all and thanks for the comments
I have been a little snowed under at the shop so not a lot done
But a small update. I have built the turret and am putting on the zimmerit coating by using a heated screw driver.
If you use this method be very careful that you don't burn through the plastic. It does take a bit of time but this is how I did it in the 80s before the PE came out lol .
Thanks for looking
Martyn Ingram attached the following image(s):
#6 Posted : 12 May 2016 16:35:19
Very nice work on the zimmerit, nice to see an old skool technique being used!
#7 Posted : 12 May 2016 19:41:24
Hi Martyn.
Looking Good, Look forward to seeing this one progress.
Regards Ian
#8 Posted : 12 May 2016 20:50:18
Thanks for the comments guys.
Yep very old school Nem but the great thing it doesn't cost anything lol
Once finished with a light sand and a coat of primer it looks quite good and I want a bashed look.
#9 Posted : 12 May 2016 21:02:25
Looking great and nice work
#10 Posted : 13 May 2016 01:31:49
Great idea for the zimmerit and it looks pretty good too. You must the patience of a saint using this method
#11 Posted : 13 May 2016 09:24:54
Thanks Andy and Dave for looking in .
It takes a little time to do but once you get the hang of it you can plod through lol
#12 Posted : 15 June 2016 11:33:06
Hi all and thanks for the comments.
A bit of a update. Er no quite a big update as I have been a bit busy at work but hayho
I have finished the Zimmerit and started the painting after that the weathering was applied.
The mud is made by getting dirt from the garden and mixed with PVA and splattered about with an old brush
The branches are made from twigs and the leaves are seeds from a silver birch tree that I have in my garden, l think they look ok .
Next job making the base
#13 Posted : 15 June 2016 13:28:40
Well the Panther looks absolutely awesome!!!! great job Martyn regards Phil
#14 Posted : 15 June 2016 17:44:04
Brilliant Martyn, well done!
#15 Posted : 15 June 2016 19:15:13
Just one thing looking at the photos the tracks haven't got enough sag in them as they are the ones that came with the kit . Any ideas on how I can get them to hang right. Thanks for any help
#16 Posted : 15 June 2016 19:56:09
Looking good
#17 Posted : 15 June 2016 20:31:39
If they are the kit elastic band type, then to get the sag right you will have to carefully glue them to the tops of the wheels you want them to touch. It does work and looks ok. The other way (and I always do if I can get them) is to replace them with individual link track sets, metal or plastic, as you can add or take away links to get the desired sag. I prefer the metal link sets, they add weight and the sag looks like the real deal.
#18 Posted : 15 June 2016 20:46:29
Cheers Nem yep there the elastic band type that comes with the kit I will try and glue them to the top of the wheels. What do you recommend to glue them with . Thanks again for the help
#19 Posted : 15 June 2016 20:52:03
Use a gel type super glue, it will let you move them about to get the right sag. Do one wheel at a time, then hold the track in place until it has dried then check it and move to the next.
#20 Posted : 15 June 2016 20:58:38
Just as a guide, here is the track sag on my Panther.
2 Pages 12>
This page was generated in 0.243 seconds.
