replacement damaged parts Options
Ian weaver
#1 Posted : 01 May 2016 10:31:39
I have just received my replacement parts only to find them damaged inside.
#2 Posted : 01 May 2016 10:57:09
Looks like the box has been cut open with a knife which has also cut into the content packs. Have flagged this with despatch.
Ian weaver
#3 Posted : 01 May 2016 11:12:44
Thanks, Tom
Is it ok to open the other packs?
They have dents in the outer packs but can't tell if the items have dents in them without opening them.
Clearly the 1 pack is scratched, but the other 2 need opening to check fully.
Didn't want to open them without contacting you first.
#4 Posted : 01 May 2016 11:19:51
Those that are undamaged you can use, please let me know which Stage packs have been damaged?
Ian weaver
#5 Posted : 01 May 2016 11:32:34
The dents in the outer packages do not appear to have reached the items inside.
The only issue is with RB7-091.
Ian
Ian weaver
#6 Posted : 06 May 2016 12:20:56
Hi
Any comments from dispatch regarding this item?
#7 Posted : 06 May 2016 16:53:17
91 is on route
This page was generated in 0.149 seconds.
