Stage 109 Options
ALW
#1 Posted : 05 May 2016 15:57:01
Hello
I'm sanding the fuselage, and the instructions say use a spare plate to check the curve but don't know which is the spare plate. The official build diary on you tube
tube says it is supplied in an earlier stage but doesn't say which stage!
Can you help please?
Thank you.
#2 Posted : 05 May 2016 16:06:26
The instructions of Stage 92 indicate the supplied spare plate in 92 and so does my forum build for stage 92 and also at Stage 109 where the spare plate is used.
ALW
#3 Posted : 05 May 2016 16:11:22
Thank you.
My mistake for not looking properly-apologies.
#4 Posted : 05 May 2016 16:13:28
Easy done with so many plates to deal with
This page was generated in 0.146 seconds.
