Nose Plate Options
ALW
#1 Posted : 06 May 2016 20:11:36
Hello
Please see attached photo.
Fuselage plate 86 in place dry, and plate 116 held up against plate 86 and there are gaps.
The part of the bent plate is slightly curved where it butts up against the centre plate, however the centre plate is straight?
Any ideas?
Thank you.
#2 Posted : 06 May 2016 20:41:07
Your jumping ahead without having fitted nose side plates. You need to add the plates in the same sequesnce at the instructions, otherwise your going to have all sorts of problems!
Initially it looks like you have the plate the wrong way round, the curved edge should be at the bottom and its straight edge at the top so that it butts to the straight edge of the top plate.
ALW
#3 Posted : 06 May 2016 20:58:49
Hi
Thank you. I seem to be having an issue with these plates! Need to slow down a bit.
#4 Posted : 06 May 2016 21:03:33
You will if you dont fit them in sequence with instructions.
This page was generated in 0.850 seconds.
