Joined: 05/10/2012 Posts: 68 Points: 114 Location: suffolk
Hi every one just got back from a winter break and found a few boxes with model space F1 on the side, so I recon I should get started. Am up to stage 17-24, and really enjoying it, going quite smoothly to eccept for the decale (very tricky)especially the helmet does any one have the positions for these? Apart from the picture its hard to know where the others go instructions say follow the instructions but where are they? By the way why isn't there a build discussion site? I found that very usefull in my last build?
The pack 3 Stage 10 instructions shows decal placement for the helmet.
RB7 build discussion is here: http://forum.model-space...aspx?g=topics&f=118
Hi Mr T Yes I've got that but unless I'm going senile I can't see any positioning places for all the decals on the helmet But saying that I and if it I am correct the air filter helmet should I presume have all the stickers on already am I right?
 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,503 Points: 4,421 Location: Essex
Hi. I found the helmet very difficult too. Have you not got the downloadable instructions for this kit? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
jethro wrote:Hi Mr T Yes I've got that but unless I'm going senile I can't see any positioning places for all the decals on the helmet But saying that I and if it I am correct the air filter helmet should I presume have all the stickers on already am I right? Page 47 arrows the positioning of the decals.
The air filter helmet also needs decal placement, though these are self-adhesive and need to be cut out.Tomick attached the following image(s):
Thanks for the pic's Tomick I'll print that off and use them Jethro
No need to, you already have it!
Simply take another look at Page 47 of the Pack 3 instructions which talks about the helmet decal placement, where you will find the exact same photo as mentioned a few posts back.
