12 Pages «<56789>»
Adam's SotS Build Options
#121 Posted : 17 March 2016 19:48:58
She's looking great Adam, you've certainly done a great job so far and long may it continue. Cool Cool The art of fitting droppers and stealers does take a little time to master but with perseverance I'm sure you'll get there in the end. It doesn't matter how long your build takes just as long as you are enjoying the experience....Cool Cool .. Look forward to seeing your next update....
#122 Posted : 17 March 2016 20:10:45
Adam
Its all coming on well.
Ups and downs with any build are to be expected but the end result proves so satisfying.
Hope the rest of the build goes well.
John Passmore
#123 Posted : 20 March 2016 05:49:10
Publisher Medal: Featured Build of the MonthOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Hi Adam
Good to see you back at last!BigGrin BigGrin
Your second planking is looking absolutely immaculate. Love the neat finish around the transom. I had a lot of bother with this area but you've done a lovely job...Well done...Cool Cool
Can you tell me what droppers and stealers are? I haven't a clue! Confused BigGrin
JohnP
#124 Posted : 20 March 2016 10:05:02
John Passmore wrote:
Hi Adam
JohnP
Hi John, have a look here... Excellent guide to planking for beginners and fully describes the use of droppers and stealers....Cool Cool .. Hope this helps.
http://forum.model-space...aspx?g=posts&t=5669
#125 Posted : 21 March 2016 00:38:43
Nice and neatly done planks. Your doing a grand job.
Chris BigGrin
AdamHall
#126 Posted : 14 May 2016 02:34:16
Very many thanks for the preceding comments. They are certainly appreciated and definitely helps to maintain an eye on the prize, so to speak, in completing this stage of the build.
I’ve continued with the second layer of planks over the past month or two. About 5 more rows to go. A long haul so far I must admit, but there is light at the end of the tunnel (and it’s not the oncoming train).
Now I need to figure out the best approach for laying the planks around the T-Junction that is the hull and stern post. I’ve planked from the keel down (or is it up? Been working on this upside down for too long). I think I need to progress inward continuing from the last of the 14 rows previously laid. There looks to be some serious twists and curves in a small area.
So, short and sweet for now.
Until next time - take care.
Adam
AdamHall attached the following image(s):
John Passmore
#127 Posted : 14 May 2016 04:28:02
Hi Adam
Lovely planking work there mate - looks absolutely immaculate...
Don't worry about the planking round the stern post - just let the planks lay where they want to go, then just put shaped infill pieces in as required...that's what I did.
JohnP
PS. Where have all the smiley's gone?
#128 Posted : 14 May 2016 07:02:28
Stunning work on the planking Adam looking sweet.
#129 Posted : 14 May 2016 10:26:34
Top work there Adam and yes, the stern area can be a little tricky to do but looking at your progress to date I think you'll get round that area without too many problems.... Looks fab...
#130 Posted : 14 May 2016 10:35:04
Hi Adam.
your planking is looking excellent, keep the pictures coming.
regards Ian
nightwisher
#131 Posted : 14 May 2016 14:26:59
Absolutely beautiful planking, but I can see a problem on the horizon.You have made such a good job on bottom of hull, are you really gonna want to cover it with paint?
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#132 Posted : 14 May 2016 16:44:07
Hi Adam
Stunning work with the planking, they're so neat and tidy!! Looks like a lot of love and patience has gone into doing it
#133 Posted : 14 May 2016 16:44:24
Really nice work there Adam...
AdamHall
#134 Posted : 20 August 2016 03:35:30
Ahoy there.
There is quite a buzz in the dockyard at the moment and it gives me much pleasure to announce that THE SECOND PLANKING ON THE HULL IS COMPLETE. There is no way I thought it would take this long to complete, but perseverance appears to have paid off.
Almost all of the bow planks were tapered to be ending at half width (2.5mm). Some have pointed ends but these are hardly noticeable. The transition of the planking at the stern post gave me the most grief. To help achieve a flowing transition I decided to flare out the top of the stern post with wood putty. This helped immensely as the planks are bent and twisted within a small area. The hull has been lightly sanded using 400 grit then 800 grit sandpaper, so now it is silky smooth.
So, now it is time to crack on and commence construction of the gallery and transom. But before we do, to celebrate the completion of this milestone, the Captain has issued an order to the dockyard crew:
“Splice the Mainbrace”
#135 Posted : 20 August 2016 05:28:12
WTG Adam,
That looks to be a top job on the planking.
#136 Posted : 20 August 2016 06:06:59
Very nicely done Adam she is certainly looking ship shape. Well done m8
scraperjawa
#137 Posted : 20 August 2016 06:28:52
Very nice job on the planking there, Adam. I'm sure it must fell great to reach this milestone in the build. I am just starting this build and will definitely be watching your progress with interest.
Stephen
Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
#138 Posted : 20 August 2016 09:59:05
Looking good Adam, you've certainly done a great job with the second planking layer. Well done....
#139 Posted : 20 August 2016 11:41:34
Adam
Time and patience has indeed paid off and you now have a great hull as the foundation of the rest of your build.
Hope it all continues to go well.
#140 Posted : 20 August 2016 16:20:56
Beautiful planking, as others have already said your patience really has pad off.
If the rest of this is done to this standard it will be a stunning show piece when you get done with it
Guest (11)
12 Pages «<56789>»
This page was generated in 0.679 seconds.
