Paint colour Options
ALW
#1 Posted : 14 May 2016 23:11:06
Hello all
I have decided to use Humbrol 163, dark green, with a view to using Humbrol 165
for the top surface but which grey for the underside and is 165 too light
for the upper surfaces?
I've chosen and tried Humbrol's aerosol paints and this is my preferred choice-great
paint finish.
There seems to be a lot of opinions on the subject of the use
of paint in the modelling world, just thought I'd see who's using what!
Thank you all.
#2 Posted : 15 May 2016 09:35:16
Hi Alan for me I will be spraying the Battle of Britain colour set from www.sovereignhobbies.co.uk
Have a look
Trev.
#3 Posted : 15 May 2016 10:00:04
#4 Posted : 16 May 2016 09:04:39
The info in this link should also help..
http://www.fritzthefox.c...british_camo_guide.html
ALW
#5 Posted : 16 May 2016 20:10:39
Thanks Tomick & Trev
Will have a look
ALW
#6 Posted : 17 May 2016 20:24:16
Hi Trev
I couldn't see the colour set you mentioned, through the link you
kindly sent?
Regards.
#7 Posted : 17 May 2016 20:57:48
Its out of stock
https://www.sovereignhob...set?variant=12905533956
But if you go back into the shop you can buy the individual tinlets listed
ALW
#8 Posted : 17 May 2016 21:02:59
Ah ok!
Thank you, I'll have a look.
Regards.
#9 Posted : 17 May 2016 22:21:33
Hi Alan,
How about Mr colour paint sets, RAF WW2 standard colour set for air craft mid to late from, www.air-craft.net.
Just a thought
Trev
ALW
#10 Posted : 19 May 2016 12:54:14
Hi Trev
Thanks, Ill have a look. It seems there were an array of colours used and I think if I paint the Spitfire near to as it would have looked, unless someone is an expert scrutinising the paint job, I don't think it will do any harm.
It's going to look good either way!
Thanks.
Regards.
This page was generated in 0.140 seconds.
