nose plates Options
ALW
#1 Posted : 22 May 2016 12:47:01
Hi!
I'm a little concerned about the fit of the nose plates. Pack 30, stage 115
instruction illustration Nos.4 & 5.
It shows plate 2 attached and covering the curved strips that will be flush with the wings (I have shaped them to fit the wing contour). In my photos you can see how plate 2 has been fitted dry, the wooden strip is almost completely exposed.
In illustrations 4 & 5 it shows the strips concealed beneath the plates?
In the official build diary the strip is also showing,albeit only slightly so I'd like to ask, which is correct? I'm worried the next plates won't butt up if this stage is not correct?
Thanks, Alan
This page was generated in 0.092 seconds.
