Stage 42 Noise Filter Question Options
kenjara
#1 Posted : 25 May 2016 08:54:06
Hi all I have a question regarding the the connection of the two yellow power wires to the noise filter. I have added the quote from the official build diary below.
Quote:
Turn the housing so its base is back on your work surface. Plug the two yellow power supply lines as shown above onto the two lower terminals of the noise filter, which is at the rear left of the housing. Push them all the way on, firmly yet gently.
My question is does it matter which way round the wires go? No order is mentioned in the instructions or the build diary and the photos show the same wire being held next to both connectors.
As far as I know this all depends on the capability of the noise filter and whether it is a dual one or not.
I hear its always best practice to match neutral and live up regardless.
Please correct me if I am wrong about any of this.
Thanks
michu
#2 Posted : 25 May 2016 09:41:50
IT will not matter which way you connect these wires.
Happy building :-)
kenjara
#3 Posted : 25 May 2016 10:14:27
Thanks michu that's good because mine really do not want to come back off hehe.
This page was generated in 0.417 seconds.
