6 Pages «<3456>
The Military Quiz Options
#81 Posted : 29 May 2016 12:10:40
correct Darren you question? Phil
#82 Posted : 29 May 2016 17:18:19
Thanks Phil, keeping on the same theme, why were the British tanks in WWI male and female?
#83 Posted : 31 May 2016 14:21:22
Females only had mg`s, where the male`s had guns 6 or 9 pounders i think? regards Phil
#84 Posted : 31 May 2016 15:07:48
Your question Phil!
#85 Posted : 31 May 2016 15:37:17
cheer`s Darren What is the largest muzzle loading cannon ever made ?
#86 Posted : 04 June 2016 12:18:05
It is the Tsar cannon built in 1586 from bronze and is on display at Kremlin Moscow regards phil
#87 Posted : 04 June 2016 12:51:11
Your question Phil.
#88 Posted : 04 June 2016 14:47:43
Ok Darren! what aircraft did Rudolf Hess crash here in the UK in WW2 regards Phil
#89 Posted : 04 June 2016 17:13:16
It was a Messerschmitt Bf 110.
#90 Posted : 04 June 2016 18:37:08
Yes Darren! over too you?
#91 Posted : 04 June 2016 19:41:53
Thank Phil.
What was the main armament in a Sturmtiger and what was it based on?
#92 Posted : 07 June 2016 12:53:54
It was a mortar which fired rocket type projectile based on the tiger 1..........Phil
#93 Posted : 07 June 2016 17:38:52
Over to you Phil!
#94 Posted : 08 June 2016 14:01:48
Cheer`s Darren the Pak 36 was the German Army`s main stay anti tank weapon in the early part of WW2, what nickname did it receive from the Germans when they met the more advanced tanks in Russia etc......regards Phil
#95 Posted : 08 June 2016 16:40:16
It was called the Heeresanklopfgerat which translates to army door knocker.
#96 Posted : 08 June 2016 18:40:57
Yes your right Darren,,,,your Question? ...............Phil
#97 Posted : 08 June 2016 18:47:33
Some German night fighters had Schrage Musik, what was it?
#98 Posted : 10 June 2016 16:48:04
was it the rear auto cannons firing upwards,,,,,,,phil
#99 Posted : 10 June 2016 16:56:07
Spot on Phil. Over to you.
#100 Posted : 12 June 2016 10:47:19
Thank`s Darren... here goes! what was the German name given to the first German 80cm railgun? ............cheer`s Phil
6 Pages «<3456>
This page was generated in 0.146 seconds.
