You've probably noticed that its been quite some time since I have started a plastic kit build. I just seem to have lost my mojo for fir recently and although I did make a start on my build of the year entry, Revel F4 Phantom, I just couldn't get into it and have pushed it aside. After setting up another desk in my hobby room yesterday and moving all the painting things, spray booth, paints etc in doors from the garage I decided to have a play around with this kit. Pictures attached of new setup. The task light is a daylight lamp and I also have an LED day light bulb in the ceiling light I remember reading a build Jase did of this quite some time ago and how he was totally unimpressed with the fir of the kit, so I though I this might be a challenge and dug out my filler. I started the usual way of studying the manual and couldn't quite work out Airfix's logic to this build, in my mind it all seems back to front. To that end I am going to tackle this in my own logical way. I will also be using the Big Blue Boy photo etch kit for this build. I started off by test fitting the main parts to help get an idea of how I am going to handle it. I have to admit the fit is terrible. I started by deciding I was going to build the bridge assembly off of the deck, when I went to test fit this back to the deck this is where I realised that the fit problems are with the moulded on parts that you are supposed to use to help you line up the verticle sections. After cutting off these parts I found that the bridge sub assembly section fit like a dream. I carried out in this manner by cutting the parts off of the deck that I needed to make the bridge assembly continuing with the smoke stack too. Its worked out rather nicely, just some filler needed around the edges now. Once this has had a good time to dry I will start sanding off the details that will be replaced with PE. davetwin attached the following image(s):
Nice to see you start another kit Dave, the etch looks good and will certainly be a big help on what is a pretty basic kit Steve
Nice Etch set for the kit and should be an interesting build Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Dave. Look forward to seeing this one come together, nice etch. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks guys
I was really stuck as to what to build and for a long time now just kept taking a box out and having a look through then changing my mind and putting it away. I think finally getting everything into one room again is what made it change. I'm really enjoying this so far so it's looking good
Looking forward to seeing how you resolve some of the fit issues, upgrades look great. She is actually quite a pretty ship Keep the picks coming Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
jase wrote:Looking forward to seeing how you resolve some of the fit issues, upgrades look great.
Jase Thanks Jase, at the moment it's lots of filler and sanding, I'm determined to make a good job of it so patience is going to be key with this one I think
Here are some pictures to give you an idea of the filler being used The PE rear flight deck will hide a large gap around the rear quite nicely. I'm finding you need to cut off all the locating tabs and you get a much better fit. Still along way to go davetwin attached the following image(s):
Looking forward to seeing this take shape, shame about the fit, but i am sure it won't hold you up with your abilities! Keep the pics coming!
Nemesis wrote:Looking forward to seeing this take shape, shame about the fit, but i am sure it won't hold you up with your abilities! Keep the pics coming! Thanks Nemesis, I've got plenty of filler to hand so its just a matter of time now. After reading up I have now just ordered some Mr Surfacer 500, 1000 & 1200 filler primer which should assist greatly.
Whilst waiting for the Mr Surfacer to arrive Ive carried by starting to apply the etch to various parts. Very slow work davetwin attached the following image(s):
looking good there Dave like the etch work very fiddley regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Your really getting the best out of this kit I did the same regarding removing the tabs, Airfix seemed to have designed parts to pull away from there position lol Etch looks fab Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Looks good and the etch certainly improves the kit Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Always great to see something different Dave, you're certainly cracking on and getting the best out of this it, well done.....
Thanks for looking in and the comments all.
Hopefully by now you can all see how bad the kit is with regards to seam lines, some of them are like ravines lol. I guess I was a little spilt but the Yamato which seemed to have been engineered so that all the big seams were hidden.
Hopefully with when I have the new filler all will be well
Great work Dave. Always like it when a Warship is built. Look forward to your progress. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hi dave. Coming along real nice. The etch certainly adds to it.cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Thanks for your comments Chris and Mick. I am now carrying on with this along side my Phantom. At the moment Im still at the photo etch attaching phase but have now purchased an Optivisor which is so much help and making things easier One of the missle bay hatches seem to have disappeared so we will just say that that one was fired off davetwin attached the following image(s):
Nice work on the etch Dave, all very neat and tidy. Shame about the lost cover for the missile launcher, but you could try just cutting a square from the discarded etch framework maybe?
An Optivisor will always be a very worthwhile purchase for any modeller and is essential if you want to preserve your eyesight? It's also a revelation as your eyes get older, as I'm sure you now realise?!
Well done Dave, nice update.
Kev
