32 Pages «<2627282930>»
tf64 Spitfire Build Options
#541 Posted : 04 April 2016 23:23:57
Impressive work once again Trev, a build showing great precision.....Love Love
mark 2
#542 Posted : 05 April 2016 06:29:43
Hi Trev BigGrin .
Simply stunning and your layout format is fantastic.
Best regards.
#543 Posted : 05 April 2016 19:49:32
Hi Shaun,
Thank you for your post to me, very much appreciated, and I must say how nice it is to have a another Spit build on the go. ( Watching with interest)
Trev
#544 Posted : 05 April 2016 19:52:00
Hi Carl,
Thank you for your kind comments still working on the nose section and pilots seat hope to post this weekend.
Trev.
#545 Posted : 05 April 2016 20:00:54
Hi Alan,
Makes me think Alan, not so worried about the rivet marking, it's all about lining up the plates, sometimes it's best not to rivet but to fit and drill the plate holes, check and check again then roll the marker along the line of pin holes. I have set mine 2mm from the edge of the plate.
All the best
Trev.
#546 Posted : 05 April 2016 20:02:53
Hi Mark,
Thank you for your time, I see your build is coming on a treat.
Trev
#547 Posted : 06 April 2016 00:46:34
Hi Trev, BigGrin
Neat and tidy as always.
Cool Cool Cool
#548 Posted : 06 April 2016 18:40:44
Hi Derek,
This has been a good kit to build I have built kit's and skinned them with balsa 1/32 in the past, and your DC3 reminds me of it ever time I look at your build, but this Spitfire build is something else, but only a few have sampled so far, I do hope De-Ago keep going and not suspend it.
Trev.
#549 Posted : 06 April 2016 20:09:45
BigGrin Looking great Trev , some top work going on hereCool
#550 Posted : 07 April 2016 20:09:13
Thank Andy for looking in more soon.
Regards Trev.
#551 Posted : 01 May 2016 13:50:30
Hi Trev lovely work on the metal skin looks very neat impresive stuff BigGrin Cool Regards Phil
#552 Posted : 01 May 2016 14:23:48
Superb work on the plating, certainly going to be a stunning kit when finished. Top job!BigGrin
#553 Posted : 01 May 2016 22:29:42
Hi Trev.
The Plating on your spitfire. looks really nice. keep the pictures coming.
Regards IanCool BigGrin
#554 Posted : 05 May 2016 20:30:23
Hi,
Tigerace, Nem, Ian.
Thanking you for your replies, I will update the Spitfire asap unfortunately I slightly damage the small nose top cover not the large engine cover, rebuilding at the moment
Trev.
#555 Posted : 30 May 2016 16:31:34
UPDATE:SPITFIRE.
300516.
STABILIZER TAIL PLATES.
Today I have fitted 4 tail plates, they fit on the upper and lower sides of the tailplane. First I test fitted all the plates to make sure of a good fit then the next part was to roll the rivet marker I set 2mm from the edge.
Next the smaller plates I think you will have to adjust these 4 plates there the ones that fit next to the tail fin and stabilizer top and bottom, on these I found that it was a lot quicker to adjust by filing the straight edge not the curve edge.
This shows the top stabilizers fitted.
This shows the under side fitted.
These pictures show the tailplane ready to be fitted to the fuselage.
Thank you for your time.
Trev.
#556 Posted : 30 May 2016 19:43:25
Hi Trev
Very nice work on the tail, Looks perfect.
#557 Posted : 30 May 2016 20:27:25
Outstanding wrk Trev, I'm alway really impressed when I see your work with the metal sheets!
#558 Posted : 30 May 2016 21:05:30
That tail is a work of art trev!!!!
michu
#559 Posted : 30 May 2016 21:09:31
Fantastic work Trev, color me impressed :)
Happy building :-)
#560 Posted : 30 May 2016 22:22:48
Hi Trev, been a little while since I last popped in, she is really taking shap, looks great, enjoying the build very much
