tubab Options
tubab
#1 Posted : 02 June 2016 00:31:04
Rank: Amateur Level 1
The new build for C57 is very useful as it is very similar to the D51 and the picts are a useful guide to the build of D51.
#2 Posted : 02 June 2016 20:04:17
Hi tubab
I cant see where you can make a comparison between the D51 and C57 trains that are currently available as each was designed to do totally different jobs on the Japanese railway system. The D51 was the freight and heavy goods carrier and the C57 was for general purpose and passenger use. So both were designed to give the maximum in there given roles.
As with all heavy engineering company's around the world standardization of parts is a very common practice and was even done here in the UK on our loco's. So to see comparable parts on both engines is a normal practice but it still will not make them the same.
For instance the water feed tank is on the top of the D51 smokebox whilst the C57 has the same unit on the front deck both units are the same but just in different positions and a classic case of standardization in Engineering.
As for your statement in a previous post that parts can be used for either engine build if you look closely at the water feed tanks there mountings are different as in the D51 having a curvature to sit neatly on the smokebox in front of the smoke stack the water feed for the C57 has not been given this feature because it has no need for it.
Therefore although the parts are of the same unit these parts are not the same and in no way could be used on another kit apart from the one they were designed to be used on.
Looking at either build to help in the build of the other has its uses as a comparison of some parts only as although the parts may look the same most will have a different mounting and attachment point so I would be very careful of using any other build than the one that is for that build
tubab
#3 Posted : 03 June 2016 12:41:34
Hi Andy,
Points taken, but I get the impression that a few lessons have been learnt from the D51 build as the whole instruction pages are a big improvement and can be used to clarify some construction points.
Regards Tony
#4 Posted : 03 June 2016 20:14:01
Hi Tony
Having already built the D51 and following the instructions with no problems on build or with the pictures provided in the PDF's I again find your comments to be somewhat confusing to other people that may be reading the information on this forum.
To point people towards another build only causes questions to be asked that have little relevance to the correct build and it could also be an unintentional way of causing the breakage or miss-fitting of parts.
Also as you have only made a few posts I was wondering if you have built either the D51 or the C57 as it would be nice to see your progress on either, perhaps by posting some pictures so all the forum members can enjoy the fruits of your labour's. Looking forward to seeing your next post along with some pictures.
This page was generated in 0.190 seconds.
