What to use for the second planking Options
jay7792
#1 Posted : 26 October 2010 08:37:17
Hi Guys... and Gals, I was doing a little forward planning last night on the Victory and was wondering what people on here are using to stick the second layer of Hull Planking down with(wood glue, super glue, contact adhesive, etc, etc)
All of your thought on this will be greatly appreciated.BigGrin
Jay
_____________________________________
Currently building:-
Deagostini HMS Victory
Amati Black Pearl
Mamoli HMS Victory 1:90 Scale
Caldercraft HMS Victory 1:72
#2 Posted : 26 October 2010 09:35:25
If its thin veneer planking, it might be wise to use contact adhesive, simply because thin veneer readily soaks up PVA, and where the water content of PVA can lead to veneer warp as the glue dries out.
jay7792
#3 Posted : 26 October 2010 12:43:44
Thanks tomick for the reply, yes it is the thin veneer planking, any specific type of contact adhesive that you would recommend?
Jay
Amati Black Pearl
#4 Posted : 26 October 2010 14:07:53
The less stringy the better, 'Alpha Thixofix'(used to be called Dunlop Thixofix), which has a gel like viscosity, thus less stringy and better suited to cleaner working, though some prefer good old Evo-stik.
jay7792
#5 Posted : 26 October 2010 15:16:58
Thanks Tomick, I will go with that.BigGrin
Amati Black Pearl
This page was generated in 0.521 seconds.
