Electric plank bender Options
wallace
#1 Posted : 27 October 2010 00:35:09
Hi guys
I have just invested in an electric bender and just wondered if ya need to wet the planks first and how do ya use it, i know it looks simple but so am i Confused and would be grateful for any help.
Mike Turpin
#2 Posted : 27 October 2010 00:56:50
If you want to avoid the risk of planks snapping, in my view it is always advisable to soak them first. The electric plank bender softens the wood by turning moisture to steam. No moisture - no softening!
Mike T
#3 Posted : 27 October 2010 02:08:07
They do work on dry wood, but take longer to bend the plank. You probably can't get as tight a radius in the plank as you can when it's wet.
Son of Bulwark
#4 Posted : 27 October 2010 10:56:03
Hi wallace! BigGrin
I have the electric plank bender and I found that you only need to wet the planks for about 10 minute in hot water. Bend the planks slowly to start heat the plank alone it length then it will bend as you make your second past, take your time and keep checking the fit.
When the plank is bent to shape hold the plank with elastic bands onto the ribs leave the dry for 24 hours before gluing and pinning in place. This will give the plank time to shrink back to size.
I would bend 3 - 4 layers of planks at a time, it's better not to get to far ahead as you need to shape some planks to fit.
ThumpUp Darron
wallace
#5 Posted : 27 October 2010 14:26:51
Thanks very much guys, much appreciated.
This page was generated in 0.355 seconds.
